My first coil using "coil winder sandwich" and lacquer bath -- not so good. In spite of spraying the wood thoroughly with silicone "non-stick" spray, my coil, coated with varathane as it was wound, stuck to the wood form, and windings were separated as I removed the top wood piece. Some wood actually broke off and stuck to the coil wires. Maybe the varathane is much stickier than Spar Varnish or able to penetrate the silicone. Or maybe I need much thicker silicone coating.
I will try to rescue the coil by wrapping in tape, but I'm disappointed with my method. It also is very slow waiting for varathane to dry, so can't make lots of coils in a hurry.
I think I chose too high a gap for the coil height - the coil thickness is too thin, not square enough cross-section.
I would like to find a way to wind directly onto a light form that can be incorporated into the coil head, similar to the video showing Tesoro making coils. I may try again my "foam core form" that almost worked:
http://www.geotech1.com/forums/showp...&postcount=129
The problem was the heavy wires forced the layers open. With lighter wire and using the new top disk on my coil winder "sandwich", maybe I can be more successful with it. However, it is not a professional looking coil and not the ultimate technique.
I would like to try some thin plastic channel, bent in a "D" shape, to wind the coils on. Then move the plastic channel into a normal vacuum formed shell or resin molded form. I don't know where to find such plastic channel.
There is some thin aluminum channel at the hardware store that would make an interesting experiment. The aluminum would act as a shield -- but maybe too much metal near the coil, it is much thicker than foil. The aluminum channel would be difficult to bend and require cuts at the bend points probably. Just a wacky idea.
Anyway, I'll try to perfect my "glue while winding" technique with more non-stick spray.
-SB
-SB
