I have been working now for a while on a compendium to repair the old IB series (IB-100, IB-200 and IB-300) from Bounty Hunter (PNI).
The compendium will contain pictures, original user manual, old advertising, and solving general problems when the detector is not working with a PCB layout and coil section.
As I don’t want to write waste in my compendium, I have some remaining questions concerning the coil. If I just missed some information somewhere, just tell me where to read it.
Below is a schema of a coil I drew.
Hardware: I ripped a pretty used and wrecked DD-coil, having 6 spares left.
Number of turns per single D coil: 24, split in twice 12 turns, shown as above (yellow back ground).
Open question 1:
Regarding the yellow background part in the above picture.
Knowing it is one of the two coils composing a balanced DD-coil, how is this coil assembly named?
Open question 2:
Does a L1=L2 ratio give a sense in such a coil ?
Wire gauge: 0.22 or 0.25 mm, enamelled
Cable shield:
2 hot wires shielded individually, the cable wire shielded again.
Values:
Measuring 7 different DD-coils I got identical R and L values for each DD-coil and the individual coils.
However, I got a problem measuring the C values.
Using a fairly good LC-meter the values fluctuated (went up and down) between 2 uF and 92 uF in the 200 uF range, in the 20 uF range they also fluctuated considerably. Same phenomenon with multi meter that could read C values.
Open question(s) 3:
Are these changing C values normal?
May it be a consequence of the coil config?
Is there a work around?
Open question 1:
Open question 2:
Cable shield:
Values:
Open question(s) 3:
