Mechanical Contact would be the only way to wire it.
Here is a way to test the effectiveness of your shield. I got this idea from building an electroscope posted elsewhere on the forum. Actually, a simple spiral wrap of bare wire around your coil can be amazingly effective, even with fairly large gaps between the wraps.
This will test the effectiveness of shielding from static charges and can sense the charge on a plastic cup from several feet away on an unshielded coil.
If the LED toggles from dark to light, it is sensing a positive charge.
If the LED toggles from light to dark, it is sensing a negative charge.
On the subject of shielding I am curious if anyone knows about the material linked below. $30 free S/H for a sheet 60" by 36" of carbon fiber cloth. I am wondering if it is conductive enough to work for coil shielding.
"Yes, the Bright Gal has a bright silver finish.
Our Cold Gal has a very high content of Zinc in the dry film so it would be
conductive.
We do not have data to say how conductive it would be, but Zinc is not a
highly conductive metal.
I was looking at some carbon fiber rods that I have for filler material in some of my coils. Just as a quick check, I checked them with an ohm meter and consequently did not use them because they were conductive. I would bet that it would work.
I suppose the idea is to find something conductive to use as a sheilding material but cannot be detected by the coil, like a mylar survival blanket.
Don
Thank you 6666 for posting the link.
I am specially impressed with the following sentence: This will test the effectiveness of shielding from static charges and can sense the charge on a plastic cup from several feet away on an unshielded coil. We have still not come to a conclusion of how much static and how much EMI are involved with the coil shielding.
We know that submersed in saltwater, no shield is needed.
We know that close to the ocean humidity it is difficult to build a static field.
Do we have any information about static effects on saltwater beaches?
We know that wet grass can be a problem. Is that due to static? or conductivity?
