Tesoro Golden Saber TGSL Problem with swinging
    hello plappermaul
    while adjusting the coil correctly (nulling)
    you should measure an AC voltage of under 10mV directly on RX coil
    on the output of the amplifier next to rx coil the voltage should be 40-50 times higher
    hopes this will help
      Hello bernte_one,
      thanks for your advise but this is not the problem.
      Read what PAKU wrote:
      yes change both other IC 308 or 393 358 Just Try And Test When You Get You Voltage On RX You have Fix That Error sound now Try Nulling Back You Coil Again
      all tested without coil
      when you have get voltage from RX then Try Connect You Coil And Nulling Again
      This is what i need to know.
      Regards.
        May be you need to check the electrical interference , perhaps your are trying to adjust the MD near a televison set o flourecents lights,sometimes inside at home are electrically noise. try to adjust outside at home.I was have truobles to adjust threshold in a surf pi and my problem was electrical interference,almost you can check if the coils in not near at the floor or are metals in subfloor. Sorry for my bad english, I hope this can help you.Regards
          PI and VLF is different
          PI is Pulse Induction
          VLF is Very Low Frequency
