Universal PI Micro
  • Originally posted by bugwhiskers View Post
    Hi mohsen,
    I think it wise to wait until it is finished and working well.
    bugwhiskers
    It`ll never happen, at the rate it going, didn`t finish the first one that just need abit filtering.
    Dazzle em with flashing lights and gimmicks....video clip...can do with nearly any digital readout, even multimeter, take sensor/coil of md and put finger, (not recommended) but prove point. This cat pull your leg...
    • This project seems to be contraversial?
      Wirechief
      • Hi Wirechief,
        It would seem to be so, particularly with cowards that don't have the courage to sign their posts.
        bugwhiskers
        • Hi Bugs, I think you have made it very clear that this is a project and that until it is tested and operational it is still in the experimental stage. Not many will actually attempt a technical project and share it with many. It is not easy to do this and I always appreciate those that are willing to help.
          Ok Bugs take care and I hope you stay with it. God Bless and take it easy.
          Wirechief
          John Tomlinson,CET
          John's Detectors
          Blackwell,Tx.
          • Bugwhiskers
            I dont think some understand the complexity of designing a new circuit testing it then going back and redesigning the circuit to fix the problems incountered then retesting again and again.
            For those negative posts I would just ignore them and not respond.
            RayNM
            • Originally posted by Wirechief View Post
              Wirechief
              John Tomlinson,CET
              John's Detectors
              Blackwell,Tx.
              I agree.
              This is a difficult project, and very experimental. I've been following this one with interest. Keep up the good work.
              • Hi Guys,
                Thanks for your continued interest and vote of confidence.
                After tinkering with the ADUC845 I have found that to get the best performance the AtoD has to be run very slowly. Whilst this is a problem for taking lots of samples and trying to keep up a good TX cycle frequency there is more than one way to achieve the objectives.
                The advantages of realizing gain through increased resolution are that the pre-amp gain can be kept low allowing earlier sampling and the advantages that brings to detecting small targets and also the fact that whilst keeping amplification of the signal low the amplification of noise is also minimised.
                The bus board with the 64 samples allowed me to work out how to discriminate. At the end of the process I was able to discriminate with just two of the 64 samples strategically placed.
                A late third sample would allow ground balancing and so the next step is to set up some OP amps to be fed from the well placed samples with the end result being one output that will be converted with 24 bit resolution and sent on to the audio stage.
                As you can imagine, the layout of this board with appropriate ground planes is critical if the noise is to be kept low. All of this takes time so be patient as I have to be also having sold off both of my commercial detectors in anticipation of a worthwhile result.
                bugwhiskers
                • Hi Bugwhisker
                  it really a good project.
                  I was trying to get samples at each 5us but cause of adc speeds I could not.
                  later saw your project .fast sampling and reading it at tx leisure tiem.really good idea.
                  this is a part from your previous posts
                  after this part I will have a question if you do not mind
                  The circuitry following the preamp gets 64 samples (via switched capacitors) of the early part of the decay waveform. The time between each sample can be as low as 100nS. At that speed it is possible to capture 64 samples of the first 6.4 uS of the decay waveform. The capacitors are then switched in turn to the AtoD of the micro and the digitized result is stored in RAM.
                  One area of RAM holds an average of all the previous samples with user adjustable software lag and another area holds the most recent. The lag is necessary to prevent small changes being swamped by the averaging. Ground signal and preamp drift will become part of the average set of samples whereas any abrupt change will be seen as a target. Because the sampling is done very early in the decay it should be possible to discriminate.
                  What is unique about this approach is the the samples are gathered very quickly and then later processed at leisure between the TX pulses. This technique obviates the need for a super fast micro and a super fast AtoD.
                  you ara talking about reading caps after delay.in leisure time.that is okay .ı understand it.
                  but
                  you also saying to take 64 samples at 6.4us .so all at the begining all your caps are charged even before entering to discrimination area.
                  you alo say averageing 64 samples.if I do this ,I have to read Ato D at the 6.4us of delay.reading 64 samples will take alot of time.
                  will I read another 64 samples of next 6.4us area in next rx cycle
                  and could not understand how to switch one cap to another at that speed.
                  btw I am not an electronist.do you use transistor which is triggered by PIc.
                  for this aim.
                  and what is the sampling speed of atmega16-64
                  can I suse 16f877 or 18f series of microchip.
                  their adc convertion time is around 20us .
                  • Hi okantex,
                    I am not sure I understand your question so I will re-phrase the way the sampling works as a flow sequence.
                    START:
                    switch 4053 so pre-amp goes to caps
                    Transmit pulse
                    Delay (wait for pre-amp to come out of saturation)
                    sample to cap 1
                    sample to cap 64 (approx 6.4 uS at 100nS per sample)
                    switch 4053 so caps go to AtoD input
                    cap 1 to AtoD, digitize and store to RAM
                    cap 64 to AtoD ,digitize and store to RAM
                    Process samples
                    Display to screen
                    Go to START
                    Post #76 has a very detailed description of how the samples are processed.
                    The method relies on sensing the difference between samples that are a result of the coil passing over a target.
                    bugwhiskers
                    • Hi Bugwhiskers,
                      thanks for yoru kind reply
                      but still there is something that I can not understand.
                      as I know longest delay is for silver and it is around 270 us .so we have to listen almost up to 300us for each Pulse.Am I right?
                      you say you take each sample at 100nS and at total 64 samples in 6.4us.
                      at the end of 6.4th us your caps wiill be charged.
                      but ie. you still have 300-6.4 =293.6 us delay period to be sampled.
                      if time between each sample is 100nS ,how can you sample all delay period in one cycle.
                      as I know ADC converters are not so fast to read 64 sample in 1us .
                      for each sample adc needs almost 20us.
                      64*20=1200us is needed to red 64 samples.which must be done inleisure time between tx pulses.
                      what is the wrong calculation in my ..........
                      take care.
                      okantex
                      • Hi oktanex,
                        The samples are only taken in the knee of the curve, depending on your pre-amp's characteristics this may only be the first 10 uS after coming out of saturation. The information about the metal type via it's "conductivity" can be gleaned from that area.
                        Essentially, if the metal is a poor conductor ie Lead and Steel then the early part of the curve is more pronounced and if the metal is a good conductor ie Aluminium or Silver then the curve is flatter. Using this knowledge and getting a sample of the early part and comparing it with a slightly later sample will give info about the curve shape and therefore the metal type.
                        Regarding pre-amp types, the prototype used an LF356 which is compensated and has a rather slow response which gave a nice curve rather than a steep drop to nearly nothing.
                        It is said that the decay curve for metals is exponential, I think the metal type must change the exponent.
                        bugwhiskers
                        • Very good work Bugw, and clear explanation of the procesus, it is a greatttt idea to switch capacitors secuencialy ,
                          shure you will have a good aproach to discriminate very well and with a K.I.S.S process ...bravo keep up good working,
                          Alex
                          PS:and for negative post came from negative and destructive mind, don't worry
                          • do you have picture of different metlas effect on LCD.
                            • do you have photos of effects of different metals .
                              I think there is a misunderstood that I will return baack after a search.
                              • Hi okantex,
                                I tried to take some photo's but they were blurry due to the noise. What they showed were 2 vertical bar graphs. The left graph represented the early sample and the other bar the later sample. With steel as the target the left graph went much higher than the right bar (about double) with Lead slightly less high. With Aluminium and Gold the bars stayed equal and rose together with increasing signal strength. With Silver the right bar went slightly above the left. In software it is easy to ignore any signal where the left is higher than the right leaving only Alum, Copper Silver and Gold to produce an audible signal.
                                Many people would be happy to just eliminate Lead (bullets) and Steel (nails etc).
                                The board I am working on at the moment has 2 OP amps buffering the 2 samples with the later sample being amplified by 2. Carefull adjustment of the second sample position so that the 2 outputs when fed to a Differential amp will produce zero volts will go negative for any signal where the first sample is greater than the second sample and a positive voltage when the second sample is greater than the first sample. Another differential OP amp will remove the buffered late ground signal sample.
                                Anyone that has a dual channel CRO could lash up the circuit and feed each sample to each of the channels and observe the phenomena.
                                bugwhiskers
