Analysis this schematic
    You posted two slightly different pictures. I suppose the first one was a mistake. (You can edit your posts for at least 1/2 hour after you make the post, if you make mistakes)
    That is where the positive lead goes, but where you put the ground lead in the first picture is wrong.
    red ok
    • ok
      now i do that,
      but tomorrow i set scope on Vp-p or Vmax?or i better say when i want adjustment by scope TP points ,if scope on Vp-p correct?
      thanks
      • Originally posted by mohandes View Post
        ok
        now i do that,
        thanks
        I think you should set the scope on DC coupling and Vp-p but I am not familiar with your scope's controls.
        Problem is, do you know what voltages you will be setting your test points to? (Because, I don't.)
          read this:
          02-26-2010, 07:38 AM #124
          georgi.g.zhelev
          Guru
          Join DateAug 2009LocationBGPosts315
          PULS STAR-G
          HI, ALEXIMUS!Hi, tuning is done in the absence of metal in the area of the coil!
          1.RV7, RV8 obtain TP3 = 0volt. dual beam oscilloscope after the tone
          the output of U6a, b. (TP1,TP2)
          2. ZERO push and relax, RV11; indicator "discrimination." 0!
          3.RV9 ;TP5 around 0.5 .... 06v (maximum sensitivity and stability)
          RV11, replaced the potentiometer (see photo PULS STAR-G front panel) is a indikator RV11.
          SUCCESS!
          03-02-2010, 08:49 AM #144
          georgi.g.zhelev
          Guru
          PULS STAR-G
          Hi,ALEXIS!1. Potentiometer RV3 (DELAY) put in a position of maximum sensitivity and stable operation of the audio channel. (do not touch more)
          2.RV5 discrimination> See ostsilograma scheme. (Q6 colector) fixed and not touch more!
          3.RV7, RV8> putting U7A (TR3) 0V. more .. do not touch!
          4 .. Potetsiometar RV11 >discrimination indicator to zero.
          5 .. Push and relax ZERO, RV11 ... indicator of discrimination> 0 <!
          UNDER INDICATOR ,POTENCIOMETER RV11! (NO RV5,RV10)
          IMPORTANT! BEFORE SETUP, OFF TV!! (ALL TV> OFF)
          CHANNEL discrimination is very sensitive! G.L.!
          • So, there is YOUR instruction. I will not hold your hand through this.
            • look this pages:
              http://www.geotech1.com/forums/showt...y-one%29/page5
              http://www.geotech1.com/forums/showt...y-one%29/page6
              and look this:
              03-02-2010, 01:05 AM #143
              Alexismex
              Guru
              Join DateJun 2005Posts320
              Hello Georgi,
              Today i have checked and adjusted the discrim , sometimes is good sometimes it fail , i use two sheet of metal 10 X10 cm one in copper the another in iron....
              please , can you give me the best adjustment for the channel X Ferros : How did you fix with RV5... at 0,, 10... 20 uS o more the window see my drawing and another thing see the photo the pot discrimination you use RV11 o RV5 tell me...you move this potentiometer to adjust the center after you push the Zero ???
              Thank you very much Georgi
              Alexis.
              THIS FIGURE NEARLY similar my figures in #171.
              what is your idea?
              • hi porkluvr
                look this and i sure my fist ,second, forth,pcbs are ok,and again i check the third
                sorry ,my English is bad , look the clip you are understand that
                http://up.toca.ir/images/1sugtssl99wig10pvgs.zip
                • HI georgi and porkluvr
                  i finish my detector but have bad depth and discrimination,
                  my coil is 380UH and can find iron door 6.5cm at 4.5cm and RED LED always on and I can not set TP5(my pcb correct)
                  thanks
                  • Maybe you need to go back and address possible problem with your preamp NE5534? I made a point earlier that you need to concentrate on one problem at a time (which was sample timing on that day) but you do not need to be skipping that issue entirely.
                    I have corrected Alex's drawing where he showed a NE5532 being at U5. To be consistent with Georgi's drawing that should be changed to NE5534 at U4, with the CD4053 being U5.
                    Otay, now it does not matter which schematic I look at, they are both the same in that respect.
                    Let us see the following (dual trace scope):
                    U1 pin-3 and U4-6
                    I'll have other requests when I get time to look some more.
                    • hi but i measure them before,
                      ok please tell me all points that need i measurement .
                      i tomorrow go my university and check all and take clip and send for you.
                      for ne5534 i am nulling,then connect my coil and measure all ics in second pcb and third(oscillograms figure)
                      just tell me please,which points
                      thanks
                      • I dont want to get drawn in here its exhausting.
                        Are you certain the preamp is not oscillating out of band - as it has no small feedback cap and stacks of gain?
                        S
                          Did you scope those two pins at the same time? I don't think so. If you cannot understand the usefulness of seeing those two signals at the same time, then you are hopeless and I have wasted my time.
                          edit: One thing though... it does no good to only look at 50, 100us of the signal. The real action happens between the U1-3 pulses, so lets see two pulses, OK?
                          Yer right, Golfnut it is pretty exhausting and I could use some relief.
                          • Hi guru porkluvr and golfnut
                            first sorry me , i think both of them think ne5534 dont work well, but i adjust it by nulling ( porkluvr said),when i want adjust all TP points not change and red LED always on.
                            second when i adjust normally ne5534(without null)i can adjust TP3 and TP4,and red LED on always too. please guide
                            look this picture i take it befor.yellow pin3 ne 5534 blue pin6 ne5534
                            S
                            please talk to me simple(sorry )
                            edit:your means i measure pin3 ne555 and pin6 ne5534 ,ok but in this picture not ok ne5534?why?,i set U1-3 on 150Us and U1-2 on 120Hz.
                            ok just need measure it?dont need measure U5-11,10,9 and U5-14,15,4(ic 4053)
                            ok i measure all ascillogram again and your wanted
                              In frame #171 you identified this scope shot as pins 3 and 6, and that was the CD4053 you were probing. Or, at least I thought so.
                              I want you to change your Alex schematic so that it agrees with Georgi schematic, as follows:
                              NE5534 = U4
                              CD4053 = U5
                              Will you do that? You need to or else I am gone because I am tired of this goat roping expedition.
                              Then tomorrow (or whenever, no hurry), I would like to see:
                              U1-3 (CH1)
                              U4-6 (CH2)
                              EDIT: Whatever THIS scope shot is, that bottom trace looks really suspicious, so let's please figure out what it is and maybe take another look at it. And could we please have these scope shots a little better in focus? Step back about 25cm and see it that helps.
                              • If that last scope shot was indeed U1-3 and U4-6, then there is something wrong. It might be as Golfnut said - so much gain that the amplifier is oscillating. Soldering a low pf capacitor across the 1.5M resistor (R20 on Georgi's schematic) might clear that up. I think 10pf might be a good value but it's hard to say what would be best without experimenting. If 10pF works, then that should be good enough.
                                That noisy display does not mean that U4 is bad, only that U4 does not like its environment.
                                After that noise gets cleaned up, that signal needs to be looked at up close, (with the coil attached). That is where you look to determine if your damping resistor R6 is a good match for your coil.
                                edit: I saw that nastiness and wondered about what to make of it, but I was under the impression that those two signals were on U5; the Z1 and INH inputs. The U5 outputs X, Y, and Z looked OK so I said nothing about it.
