Need this circuit printed circuit board
  • #76
    Hi Watanabe
    Congratulations success
    -for Surf PI or Barracuda ,I expect results equal to.
    -pcb should reflects,So it took from you a great effort in installation.
    best time
    j.
    • #77
      Hi Freddy67
      I wish you success Also - thinking a lot before start if you mean Tarsos vlf,Suggested TGSL that completed,all information about pcb, coil available.
      best time
      j.
      • #78
        Hello Freddy67
        I made a mistake and printed the layout (solder side) reversed ... but only realized when welding ... so I decided to weld anyway . Integrated circuits and some other components were the same solder side ...
        What is "tarsi"??
        • #79
          Hi Watanabe
          not worry to not lose the joy of success.its work,,,,
          best time
          j.
          • #80
            Hi Jap and Watanabe
            Tarsos detector can be found here: http://www.geotech1.com/forums/showthread.php?t=14595
            Pi is finished and is working. Are only the casing.
            Best time.
            Jap, you are in what country?
            • #81
              Thank you Freddy67 and Jap
              When constructing the body of the metal detector, I will show some pictures.
              Thank you all.
              Greetings from Brazil.
              • #82
                http://www.youtube.com/watch?v=12GXE...1&feature=plcp
                • #83
                  Hi Watanabe
                  Watching the video, I thought a plumbing course with electronic anti limestone but it is indeed a detector .
                  Very good job .
                  For my part, I used a crutch
                  I realized the "tarsos" but the comments confirm the result ( good )
                  I started Cesar and I hope there will be better results.
                  Greetings
                  • #84
                    Hello friends.
                    Here some more videos on my metal detector "Polish-PI".
                    It works well, but does not discriminate metals, so I just finding much "junk".
                    I intended to ride the "PI-SURF", but as this does not detect metals do not know if I'll ride it.
                    Anyone have any suggestions detector with discrimination??
                    Thank you all.
                    http://www.youtube.com/watch?v=h9Iw-...&feature=inbox
                    http://www.youtube.com/watch?v=l5gFd...hannel&list=UL
                    • #85
                      Hi Watanabe
                      Very good job and nice family.
                      I feel that my detector is more sensitive. I'm picking my car for more than 2 m and a knife like yours more than 40 cm. But this is a PI and discrimination, I just built the Caesar but have some problems with settings. It is easy and cheap to make and the results seen on Youtube are excellent.
                      Greetings from France
                      • #86
                        yes. King Cobra. I have ordered second bunch of PCBs and will inform the forum as soon as its will arrived. you are on right way now.
                        • #87
                          Hi Watanabe
                          good work.
                          best time
                          j.
                          • #88
                            Hello freddy67
                            You're right. The sensitivity of my detector is very low.
                            I guess because I used 'TIP41 (T1). Perhaps if replaced by a MOS-FET transistor, improves. I'll check that later.
                            Have a link (URL internet) for this "Caesar"?
                            kt315
                            I will inform about "king cobra"
                            Thank you friends.
                            Best regards.
                            • #89
                              For the output transistor I tried with TIP 31 and the results were good. Rather, I think a problem head.
                              The link for Caesar http://www.geotech1.com/forums/showt...st-Wanted-quot
                              • #90
                                Thank's Jap
                                Thank's Freddy67
