PICKINI - an easy to build PI detector
  • i have finished my pickin from post 200
    works
    but have to make right coil and make sound a little bit louder
    thanks all for posting results
    • Looking forward to some pictures of Your build, Bernd
      Best regards,
      - Bernard
      • made first test today, coil from older surf pi project around 290µH, 27cm diameter and copper tape shield
        must say wow
        2€ coin 25cm in air - that is ok
        but also small 5*10mm 0,39gr. gold nugget around 2cm
        bronze buckel over 35cm
        clear detection like principle hole or nothing
        can stay over target for pinpoint- tone stays
        no trouble with tuning pots or trimmer
        switch on and go
        im going to set right damping value for my coil but feels like it is already in right area
        was fine work
        Bernard
        • 2€ coin 25cm in air - that is ok
          The 1, 2 and 5 eurocent coins may even give better results, since they are iron coins with a copper coating.
          On the beach, I find a lot of these since most "more sophisticated" detectors will discriminate them.
          Since the 1 and 2 eurocents will disappear gradually, they may become collector's items !
          Best regards,
          - Bernard
          • I apologize for asking this scheme chips (integrated circuits) have to be programmed?
            • farafero,
              yes, You need to buy the Microchip Pic microcontroller and program it with a hex file available here : http://users.telenet.be/willaert/MD/.../software.html
              or have it programmed at your local electronics shop.
              Best regards,
              - Bernard
              • Originally posted by F117 View Post
                To program the PIC, I use the PicKit3 USB programmer
                http://www.microchip.com/stellent/id...irects=pickit3
                Who can point to cheap way to program PIC? For example to program Attiny I am using USBASP programmer ($2.70 on ebay, ships free from China) + Khazama AVR Programmer software (free).
                PicKit3 USB has been offered by Microchip for $45 and that is unrealistically high price.
                There should be a cheap alternative I hope.
                I have found one USB PIC Programmer for $10
                http://www.ebay.com/itm//200944364396
                Hope it works.
                • Do yourself a favor and buy a real microchip pickit, there is a thread I started here on the problems with cheap imitations.
                  There are 2 pickit programmers, you have to look very carefully to see which one will program the chip you want to program.
                  I have both, so I can program the whole range of pics.
                  For AVR I use 4 resistors.(10 cents)
                    "AVR Serial Port Programmer" Good idea! It have to be included straight into Chance PI schematic.
                    • what kind of speaker should be used
                      i tested some miniature loudspeaker (non piezos)
                      but they are not loud enough i have also removed the 1K resistors before the audio output
                      but this results in constnat tone when settignthe sens to 50% and higher
                      had also tested a small piezo which was removed from an old electronic toy (not all types work)
                      sound was also not loud enough
                      last solution would be to connect an 3,5mm headphone connector and use headphones but i dont like headphones for beachhunting in the summer
                      • The cheapest earphones you can find are sufficient - small in-ear phones, since the sound is digital (tone or no tone - just a one second tick).
                        As "real" loudspeakers I once used a 50 ohm speaker from a telephone - not the one in the horn, but the one used when the phone is on speaker. Something like this:
                        http://www.conrad.com/ce/en/product/...aker-50-360-Hz
                        With good headphones, I normally use a volume control to reduce the sound level as it is too loud.
                        but this results in constnat tone when setting the sens to 50% and higher
                        This points to unstability - once the sensitivity is set too high and disturbance signals are picked up.
                        Inside the house I can only turn up the sensitivity very little -- outside, away from interference, you can crank up the sensitivity.
                        Best regards,
                        - Bernard
                        • i tested the but only loud enough without the 1k resistor
                          http://www.conrad.de/ce/de/product/7...-1-St?ref=list
                          http://www.conrad.de/ce/de/product/3...-1-St?ref=list
                          but seems that i have to leave my house , and the problem with false signals without the 1k resistor will remove
                          thanks bernard
                          • Build a simple 1 or 2 stage amplifier for it using a 2-3 transisitors , dont try using a chip as they all seem to have AGC built into them which is no good with these projects.
                            Will work a universal type amp out later today for you all.
                            • long time ago i write over a simpler headphone amp something like a one channel cmoy
                              but i think it is too much
                              a simpler solution is better
                              hope for your design soon
                              thanks
                              • Power Amp
                                Hi
                                Can one of you here please tell me what the output power is in normal use in presents of metal and output without detection and then maximum output.
                                Also like to know optimum output impedance if possible.
                                Just measure with volt meter across audio output terminals and set scale to 500mv or so, then I can get started working out something very easy and simple.
                                Regards Dave
