unfortunately i dont have a scope only a multimeter it can measure frequency and duty cycle inductance and capacitance and the normal stuff
help with surf pi kit no sound
could it be the coil making it very low in sound ? if touch the coil with bare skin enameled wire and and pin on volume pot turn voulme to mid way the sound comes up to an useable level constant tone still dont react to metal try delay adjustment makes no difference
So far it looks like the power supplies are working OK, and the correct power voltages appear in all the right places. The null-offset of the preamp can also be adjusted to 0V, and a magnetic field is being transmitted by the coil. However, without an oscilloscope, the cause of the problem is going to be very difficult to find.
I'm a bit concerned that the preamp output (TP2) is still 0V with the coil connected. Does the voltage increase by a few mV if you put a large metal target near the coil?
i read setting it up tp2 was to be set at 0v is this right do i set it with the coil off or on the offset is a bit touchy down to the last few mv and all ways changes the next time i test it as for large metal object how large i will try and post results soon thanks for helping again i might be able to gain access to a scope but never used one before
Originally posted by alcartraz View Postok a little more playing around i found q6 11.97 going in on collector 0 volt on base 0volts on emitter ?
There should be a square wave at the output of U4D that is used to switch U7D (4066) on and off. This means that Q6 base is either at 0V (4066 turned on) or is biased to a higher voltage by U3A (LM356) when a metal target is near the coil (4066 turned off).
I know someone asked this earlier, but are you sure the link above R16 is inserted?
Looking at the original White's circuit diagram for the Surf PI, I notice that it has an audio transformer in the collector of Q6. This implies that the speaker needs to a high-impedance type, if you're not using a transformer.
Originally posted by alcartraz View Postbeen playing some more the volts on tp2 goes from 0 volts to -1.9 when near to touching a metal object made of steel and yes the two links marked with white lines are there and good
Looking at the schematic, I would expect the signal at TP2 to go positive when a metal target is present.
Alcartraz - tell me about your coil. What is the diameter, and how many turns?
