fitting a new lithium battery to an old original minelab sovereign
  • #46
    you may take one from righ part of this table, but if you take one from middle part you have to REVERSE it, mirorred, on set.
    you may not take one from left column.
    what does the P and the N at the end of each number down the columns stand for.
    • #47
      P is P-N-P type. N is N-P-N type. THE structure of the transistors. your type seeking is PNP. the emitter's arrow looking inside, at circuits.
      • #48
        P is P-N-P type. N is N-P-N type. THE structure of the transistors. your type seeking is PNP. the emitter's arrow looking inside.
        i got ya.......
        • #49
          well the detector is fully working again now as it should do. i only replacing the Q7 BS170 transistor first and the detector was working fine when i tested it. so i left it at that.
          i really do appreciate all the help that i have getting from you guys.
