Help for Anker SS60
  • #31
    Anker Help for SS60
    Problem . SS-60 do not work good . Maybe to has selfoscilations. It beeps at low and high tone together. When i put the probe of osc near the probe it beeps more. General i have not a time without beep. Maybe the coil is bad, who knows (i don't know). The oscillator run at 5.4 Khz. Does anyone knows at who Frequency does the SS60 work?
    I wait
    • #32
      i have told you to make Tunder.
      Anker is not stable and dificult to adjust angle of metal reaction.
      have to see table of channel reaction from three different probes - ferit, iron, cu, after that change + or- comparators in phase detectors to achieve this table.
      have to cut off one attack modul and stay with one changing serial resistor with bigger.
      from the real soil rezults are more terrible.
      • #33
        Hi rumensat. I have readed all this who you say but the problem is that there is not silence mode. All the time the detector beeps low or high tone or together. I have not made it coil so i want to see if it will work perfect then to build a 39cm coil.
        Do you know who is the ss60 frequency?
        BTW do you have the schematic of Tunder?
        I believe that a classic III with a 15in consertic coil must be the best (very stable, good sensitivity and good discrimination). Simple my hobby is to construct detectors.
        Ivconic what are you say??????
        • #34
          freqency is 6.2 khz
          this beeps are from not right moving (up or down) in channels.
          or may be you make mistake with pc board - wrong connections?
          here is the schema of Tunder with my remakes
          www.acs-bg.net/temp/Thunder-4.gif
          www.acs-bg.net/temp/TUNDER4-REMAKE.zip
          here is clasik3 remake - work good and stable in normal soil
          www.acs-bg.net/temp/clasik3-remake.zip
          • #35
            freqency is 6.2 khz
            Thanks rumensat . But i can not see anything at Thunder-4.gif (an empty page) and can't download Tunder4-remake.zip. I download the classic III (i have it at some versions)
            • #36
              mistake
              www.acs-bg.net/temp/TUNDER4-REMAKE.JPG
              www.acs-bg.net/temp/Thunder-4.zip
              now working
              • #37
                Thanks rumensat. I received the schematics. Now i will build the classic III and after it maybe the thunder-4. I must read the schematic first.
                • #38
                  Help AGAIN again again
                  Hi All.
                  Before some days i finished the classic III. To be sure about the classic performance i made a 32cm DD coil. So it was way to try the Anker SS60 with this coil. I connected the coil to SS60. The waveform is the same as aurthor sees at anker 50. The frequency is 5.98 Khz. I am near the theoretical frequency so the coil is good . I regulate the 90 degrees frequency shift. I check it. Medium results because i can't give full sensitivity. I have again a selfoscilation . If anyone knows russiam and can translate from anker Web-page i want to tell me how to regulate trimmers R26, R27 and R43. What does it says at R33 and R35?:confused:
                  • #39
                    Hi All.
                    hello geo, i have one big hamer for sale for you mjmj detectoman
                    • #40
                      Hi detectionman. Why to buy your hammer:confused: ? I have one 5Kgr and i believe that it is enough
                      • #41
                        It Works
                        Here again. Ok the Anker ss60 works . Nice audio , two tone but.....:mad: . Low sensitivity . With a 32cm DDcoil it detects a 25mm coin at 30cm:mad: . About the same with CL3. Where are the 60cm....or 50 or 45cm:confused: :confused: ? I will play with it some time yet. If i will have better results i will write you .
                        • #42
                          Better
                          After i solved two errors the results from ss60 are better. So for a 25mm coin (2Euro) the ss60 detect it at 40cm and a 30mm bronze coin at 45cm. I have not yet the 60cm (maybe with a better coil) but it is a good detection distance . More...Later.
                          • #43
                            ok geo, you do not need my hammer my congratulations for you, you is one record guiness constructor, of best detectors, hahahahaa
                            best regards
                            • #44
                              best regards
                              • #45
                                Hi GEO and other peoples that built ANKER SS60
                                Please more explain about it .
                                Regards.
