ATiny-4
  • #61
    Hi 1843
    Mosfet is not damaged. Of course a reducing at the gate voltage it is nesessary. But the best solution is to find the IGBT transistor. Today i tried with NE5534 and i had better operation, better stability anb a little better depth!! After 2 days i will go to Athens and if i have free time i will looking for AD844 and the BUP213.
    Hi Geo, how your tinny project?
    • #62
      Hi. I connected an IGBT transistor (BUP213) and an OpAmpl at input (AD844 in replace to LF357) but..... I don't like it because it is not stable. I let it in the corner........ When i will have time, i'll play again with it. This time the sensitivity is about the same with the Delta Pulse, but it needing tuning every 20sec...
      Maybe next month to have news.....
      • #63
        Hi Geo
        Which one is strong and better,( delta pulse - sniffer-xr71 ) or ( PD3200 ) or ( Atiny-4 ) ? why ?
        Thanks .
        Iman Boroumand.
        • #64
          Originally posted by Belief View Post
          Hi Geo
          Thanks .
          Iman Boroumand.
          Hi.
          Delta and XR71 are exactly the same.
          I have not tried the PD3200.
          For small and normal objects ( with normal coil, not with 1x1 m) ATiny-4 is better. It has more gain at received circuit from DP and more transmit Power. But my Atiny4 was not stable, so i let it.
          PD3200 (a friend own onn) it is about the same with DP but has the advantage that it can discriminate betwen ferrous and no ferrous objects.
          • #65
            ATiny-4
            Dear Geo
            Can u upload ur Final ATiny-4 Schematic,PCB and partlist here pls?
            Thank u very much
            • #66
              where to find it...
              "One problem for the time is the IC...HCPL3120. Does anyone knows where i can find it or if there is a similar one???"
              Mouser electronics lists that part # and carries several variations of it. Digikey may have it too...
              Just google those two names, they've both got web sites.
              gm
              • #67
                hi all friend
                I search fuse to program Attiny15L
                thank you so much​
                • #68
                  Originally posted by pigeon View Post
                  hi all friend
                  thank you so much​
                  Dear Pigeon, Would you share schematic for this project?
