Originally posted by sadowski25PL
View Post
Tesoro Eldorado
I built the Eldorado, But Not the performance is the one you specified. Discrimination does not work. in all metal, detects a coin to 20 cm.
I want to rewind the coils, and will ask if you can use this type of cable, and connections shown in the schematic to connect the coils?
The detector is built after Ivconic scheme, thanks this way.Attached Files
Hello,
I have big problem with My eldorado...
Before I try another cable, I use a LIYCY 6x0,25 cable with copper shield.
On that cable in air test for 2cm coin I have some about 32cm, Discrimination works very good.
But when I try VGA cable from computer monitor...
Tx voltage fall down from 15V to 8,3V o.O
Receiver works fine, but Transmitter dead.
Max in airtest is 10cm for beer can ( full).
Can you tell me where is the problem ?
Please help. How to prepare the coils? What are the correct parameters? What is the diameter of the coils? How to turns the transmitter and the receiver coil?
What is the inductance and resistance? Which is better, the DD or OO? Sorry for the bad English. Thank you.
hi Ivconic.
I need your help for a very some question.
Please contact me
I am french and my name is florian
lanziflorian@yahoo.fr
Merci beaucoup
Originally posted by kelt View PostHi ivconic, i almost finish my metal detector tesero eldorado made in you circuit and i ask you what capasitor you put on pin 8 lm308
There are two pcb's i done. At first one i put 100pf and on second one seems i omit capacitor?
LM308 usually need external compensation and usually it is 100pf.
But right now i am not sure to tell you why there is no cap at all at my second pcb!??
Here are both pcb versions i done than.
Both are working good (as i recall).Attached Files
