King Cobra PCB
    I believe Moha... you are on the right way now... after longest roving into geotech labyrinthes... you come out from duskiness to light.
    hi
    with your help .
    • GERBER1?
      I could say all this right, you double-compressed PDF so it would be easier to print but not if it's okay if I would say okay.
      PDF is the gerber King Cobra ..: Ceño fruncido:gerber1.pdfgerber1.pdf
      • SaBIOS dear friend, welcome to King Cobra forum! your espaniol is PERFECT! to my sorry my level in your native is equal full zero =(
        • Originally posted by sabios View Post
          PDF is the gerber King Cobra ..: Ceño fruncido:[ATTACH]29806[/ATTACH][ATTACH]29806[/ATTACH]
          it is correct PCB??????????
          • Originally posted by mohandes View Post
            • check the diagram and C41dice is 47uf and the list is 220 uf 10v this is correct?
              otherwise the plate dimensions are 15 x 11 cm right?
              • sabios;190457]check the diagram and C41dice is 47uf and the list is 220 uf 10v this is correct?
                this cap is bypass capacitor (decoupling cap), NO big differency what you will stay. in range 47-220uF all will be OK. I stay 220 and this why in part list 220.
                only cap dimension on board place limits cap value.
                Board size 122,7 x 91,3mm
                • Another question Q2 to Q8 are replaceable BF245 by 2SK246, and also C1 50pF can be replaced by one of 47 0 51PF truth?.
                  And also the SMD capacitors have about 16 or 35v 47uf which would be better.
                    directrly not. pins are unfitable. electrically maybe yes. pins of BF245 is GSD, same like for TIS75. I choiced BF245 because
                    they are at low price at ebay.
                    yes, certainly.
                    SMD tantalums you set according a voltage on lines of the schematic. not some definition what is better. if 8V you stay cap on 10V and more,
                    if 12V you stay cap on 16V and more, if you see 6V you stay cap on 8V and more, if you see 100V you stay cap 150V and more.
                    • Comment
                      • Comment
                        • http://compass-metal-detector-forum.....html#a7333572
                          I have over 300 of the Gold Mountain control housing like on their Cobra and Thunderstick models NEW and pre-drilled I'll sell cheap. Have no use for them if you hear of anyone interested let me know. Keith 903-734-7773
                          • Just rec'd a couple from Keith
                            • I just rec'd 2 control boxes from Keith Wills. They are a perfect fit for the Mirage.
                              It will hold two 4 AA cell battery packs to give you 12 volts. You may find a lithium ion rechargeable pack to fit as well.
                              The face plate may need some hole filling if you want to use 5 pots and switches and or use smaller pots.
                              Boxes weigh 7 oz.
                              Size 5 7/8" long, 4" wide, 2 1/4" high
                              • can someone send me the email adress from keith?
