IDX-PRO+VDI
  • Originally posted by CDI View Post
    Less than 100mv, my last 11" DD has now 40mv and works perfect. Coil for Eldorado is not good idea for idx, why just not make coil by specs posted many times here on forum?
    Thanks CDII read the instructions for the coil, I have to build it.
    I wanted to somehow verify the operation of the various stages, I worry about the non-detection in all metal and do not know if it depends on the incorrect phase shift (20 degrees).
    it happens that the pin 6 U1 I measure 4volt pp targhet detects and performs discrimination mode but not detected in all mode.
    if instead perfected the nulling for 400millivolt to pin6 U1 detects all metal but does not detect it discriminates so discrimination
    or should one or the other goes, I read somewhere that the phase difference must be 180 degrees, is the problem?
    sorry for the bad English !!
    coils TX 6mH RX 6.6mH
    thank you
    John
    • Originally posted by gallico58 View Post
      thank you
      John
      I said 40mv. That's measured on my scope.
      400 mv is too high. It can work with 400mv but with original idx coil specs, i'm not sure if can with eldorado coil, cause i never tried.
      Do not waste time and nerves, it's much easier to make coil according to data posted here than making some half working Frankenstein.
      • Just a quick question is the pinpoint switch meant to no or nc?
        thsnks
        • Hello
          Pinpoint switch if open working in discrimination
          pinpoint switch if closed works in all metals.
          my problem is 100% coil fitting construction, PCB Silverdog ok.
          • Thanks.
            I may have a bad u5 as my detector is only working in pp mode but constant full tone in dis mode..
            Could some one please give me some volt readings for the u5 pins.
            My Readings are as follows..
            1 - 3.23v (no swing when passing metal over coil)
            3 - 140MmV (large swing when passing metal over coil)
            5 - 4.5mV (slight swing when passing metal over coil)
            7 - 550mV (swing when passing metal over coil)
            • I am struggling with this constant tone problem i am having can some one please give me a idea on what i should be testing?
              My u5 pins are measuring..
              pin1 - .8v with swing on metal object
              pin14 - .69v with swing on metal object
              so i would assume the circuit is working up till that point.
              Thanks.
              • hi
                any body have VDI programing.(no hex file, master file)
                how it is work?
                about 2tone,any body can explain??
                • Originally posted by mohandes View Post
                  hi
                  how it is work?
                  This is connection for 2 tone. Click image for larger version
Name:	conection IDX - 2 tone.PNG
                    This is connection for 2 tone. [ATTACH]39490[/ATTACH]
                    thanx
                    but i need to explain about VDI schematic and how it is work.
                    • http://www.ebay.it/itm/-/232343744941?
                      • Originally posted by bandito View Post
                        Looks interesting.
                        • Bruh, is this board layout from eduardo here, still worked without update? Im already put most of the components
                          After i browse, most of the pcb picture have 10k trimport and 3 zener diode.... Should I continue?
                          • Originally posted by ripsdevala View Post
                            [ATTACH]39843[/ATTACH]
                            Yes work as it should
                            • Okay, thanks koala
                                hi
                                i need explain about 2tone and VDI working'
                                can explain me
