IDX-PRO+VDI
  • If you start to assemble the components on a pcb you have to continue to do it as per the scheme you cannot make changes. Different pcb for idx have been made, each one with different assemblies and modifications.
    • good night I took a look at my pcb I replaced the components that were wrong but unfortunately not much has changed still arriving only 20 centimeters in an outdoor coin can it be the coil?
      • It is different when the object is in the ground. So far no one has dug a coin more than 25 centimeters
        • Originally posted by bgs View Post
          my idx pro only adjusts in tresh and the other gb disco sens settings don't change when i adjust
          • if I do not connect the pimpont wires on the pcb it will work as if it were always with the pimpont on?
              good afternoon bgs would you have the construction data for the idx pro home coil?
              the frequency and inductance that the coils should be
              I did mine, but I can't adjust it in (gb) (disk) (sens) only in (tresh) the adjustment I don't know what's wrong
              • Originally posted by dgm View Post
                good afternoon bgm would you have the construction data for the idx pro home coil?
                • Originally posted by Uiliam950 View Post
                  What are the measurements of your Uilian950 coils?
                  • I have just finished building the IDX PRO and I have used the coils mentioned by Eduardo.
                    • When I ran or turned on the IDX PRO for the first time I did not get any audio. I was surprised that it worked with some LF347N, you have to be careful at this point it seems to me that there are ICs that do not work as they should be.
                      • My IDX PRO, neither the GEB nor the DISC works. Sensitivity I can barely distinguish. I need to configure it correctly, I am going to reconfigure the coils. I have only run it for the first time without seeing if the frequency in TX has changed. I detect all metal and ferrite but as I said before the GEB and the DISC do not work.
                        • Originally posted by Ruben2000 View Post
                          good night coil dd 27 cm rx 270 turns wire 0.16 mm and coil tx 34 turns wire 0.60mm I haven't measured their inductance yet because my new multimeter is about to arrive
                          • good afternoon someone help me how do I measure the coil frequency with a multimeter with a 20mHz frequency scale
                            • of a coil disconnected from a detector? naked coil?
                              • what I would like to know is if measuring the coil frequency is done with the coil connected to the idx pro board or is it in some other device
