IDX-PRO+VDI
  • Originally posted by strujas View Post
    Fabian you have one little mistake on your board. R3 need to be conected for other side of R4.
    Thanks Strujas, You´re right. I corrected it already.
      RX cap can be critical to tune up closely.
      Generally it is close to 0.033 (33nF). But if you put just 33nF that will not do.
      Better put 22nF + .... in parallel , close to 33nF..
      Be patient and give it chance, try to tune it as closest as possible.
      Once tuned - hell of detector !
      Deepest from all hand made presented here on Geotech forums.. no competition at all!
      Just obtained one of these Fisher coils, I measured TX=1mH RX=6.98mH
      How do I calculate the correct caps ?
      • Originally posted by silverdog View Post
        Silverdog, what is resistance of TX and RX windings in your Fisher coil?
        • Capas for Fisher
          Silverdog
          In one of Ivconics mails he says what values of capa to use with the Fisher coil
          • For Fisher 27cm search coils; RX-capacitor=33nF and TX-capacitor=330nF.Regards!
              I'll measure resistance when I get home tonight
              I tried Ivconics 330nF and 33nF, it didn't seem to be right
              Is there a scope picture on here somehwere that will help me set RX correctly ?
              • idx
                http://www.youtube.com/watch?list=HL...&v=5GMUBa5MJ2k
                  Hello Silverdodg
                  Here is a photo of the cancellation coil, my IDX_PRO
                  RX seems to work best near 90 degrees as in the photo.
                  16 volts for TX, 2 volts for grid
                  + or - 150 mV for RX, 50 mV per grid, pin 6 of 5534.
                  Greetings Jose
                  • eduardo 1979 What are the parameters of the coil ?
                      I have TX 1mh 6ohm RX 6.98mH 30ohm
                      • EDU two tone board
                        Has anyone got the EDU IDX pro two tone board working? Mine works ok for steel- deep tone, but when I try non ferrous such as a penny, quarter or dime I get one half the depth that i got before and terrible static.http://www.geotech1.com/forums/image...milies/mad.gif
                        • selim. Resistor value U2?
                          • Originally posted by shansov View Post
                            Resistor=100K
                            • Thank you.
                              • You're welcome.
