IDX-PRO+VDI
  • Originally posted by ossamaussama View Post
    Hi all
    I have a qusetion which is better idx or tesero lobo
    pretty much the same with most of these home built or factory detectors. IDX if built well will preform as good as most modern detectors if you use 0 discrimination. So on quite fields is one of the best.
    However I have also built the Tesoro Bandido and this is my main goto detector because with enough discrimination to eliminate small nails and the IDX set the same it has a very slight edge.
    Also the Bandido has true no motion all metal mode. Comes in very handy to tell the size and shape of objects and great around tree roots.
    Not tried the Lobo so can't compare.
    • Hello. Who knows what the variable is used instead of a permanent control? The scheme specified by an arrow.Click image for larger version
      • Hi all
        Why my idx cannot detect coin when it is near the coil but can detect at 35 cm
        • Originally posted by Artyom View Post
          Hello. Who knows what the variable is used instead of a permanent control? The scheme specified by an arrow.[ATTACH]35124[/ATTACH]
          it's a mistake it is correct
          Gaby
Name:	111 correct.jpg
          • Mi dispiace che non ho ancora capito se sei riuscito a eseguire IDX con due toni, e se posso spiegarlo meglio. Grazie mille....
            • Originally posted by dgm View Post
              • Sorry for the language , but I have not yet figured out if the MD IDX pro 2 tones you've managed to make it work ?
                  if you follow the scheme and using potentiometer P7 go into discrimination (remove iron) surely you have two tones, just be careful PCB collector Q3.
                  Gaby.
                  http://www.geotech1.com/forums/attachment.php?attachmentid=35064&d=1454863990
                  https://www.youtube.com/watch?v=3q8EeLJC17Q
                    i see very archaic russian word "desno" that means (AT) RIGHT. "desnitsa", is right nand in russian forgotten. what your native? what country you are from? where you got this chematic from which forum?
                      Hi all
                      First time I have seen this. Will it ground balance ferrite.
                        Word "desno" is serbian, it means "right", and this schematic is from Serbian hobidetektori forum. Second thing - this schematic is for Whites Classic 3, not for IDX.
                          yes it can reject frite in all metal and discrimination mode
                          i change rx capacitor and still have the problem with large copper target
                          small coin can be detected very near the coil\
                          but large bronze coin can be detect only if it 5cm to 35 cm
                          not less not more
                          is it saturation problem in amplifer stage ?
                          is it normal?
                          in all metal ( pin point ) it can detect large copper very near the coil
                              not less not more
                              is it normal?
                              35cm on large coins is normal.
                              Not detecting if close to the coil is not
                              I have no ideas hope someone can jumps in. Only thing I can think of is the phase is altering and the target is being discriminated out as iron
                              Is it the same in all metal mode
                              • Today i tried to null coils on my second idx, but there is weird problem. When i measure U1 pin 3, i got constantly 0.9 volt's. No changing voltage even with moving coils.
                                Measured AC 200 on multimeter.
                                What's the real nulling point on idx board? U1 pin 3 or?
