IDX-PRO+VDI
  • VDI.LAY
    • Thank You! Köszönöm szépen!
      Another question: can I use the original coil of 3900/D Pro for this project? And the Blue 1500-er?
      • elbombaci
        is this the correct way to wire the encoder
        just comparing the drawing with the physical encoder picture
        tag #7 looks like the tags on the body
        • Hi 6666,
          It is true.
          • Very good video elbombaci!
            • Thank you eduardo1979
              • eduardo1979. working archive (Geotech_VDI.rar) ? this is the end result?
                • Yes.
                  • should behave as IDX-PRO without the coil?
                    • Ko ce drugi do SRBIN!!!
                      Originally posted by mikipn View Post
                      Never say never
                      http://www.youtube.com/watch?v=d-JH8..._order&list=UL
                      Happy New Year 2012
                      Good work!!! (svaka cast!)
                      • Hello to all,
                        I have finished my boards and all the parts found on the internet. will order the parts over the weekend. I will also try to build the coil itself. but have problems to get the right wires. I can also take other than 0.7 mm2 and 0.15 mm2 for?
                        bye
                        • eduardo1979.very weak response to the coin, about 10 cm. that might be? using film capacitors.constant noise.
                          • PIC16F88 programer?
                            Wich programer i can use for programing PIC16F88?
                            Can i built epic programer from second page post #31
                            Is he working good?
                            • Possibly an alternative PIC?
                              Is he working good?
                              I was recently wondering, just how much bandwidth is needed for the VDI Unit that Holyuser (I believe it was him, apologies if I am wrong) designed and made? Because if say a PICAXE chip was fast enough, there is no programmer needed, just a serial or USB port cable and its possible to reprogram "in situ" so to say.....so a change of function could even be made in the field provided a laptop was available!!
                              The PICAXE chips run basic, but up to 40Mhz, so it could be possible, but only Holyuser could say for certain.
                              The chips are exceedingly cheap and very flexible in usage, anyone needing more info can ask and I will send them a good link to get them started.....By the way, all software and manuals are all totally free to download as the company Revolution Education designed them with financial assistance from the UK Government.....
                              Andy
                              • DIY progammer+software
                                i found some programmer with software on a german site. might be interesting for some.
                                pic: Programmiergeräte
