Originally posted by Firebox
View Post
IDX-PRO+VDI
Originally posted by reiv View PostIs it normal that the Idx reach a 16mm diameter coin at about 30cm in air, but Vdi reach her only at 12/13cm - it is not even a half range of detector ?
Originally posted by eduardo1979 View PostMy VDI does not reach far, about 25 cm in air. I changed the op amp several times and also improve outcomes. Instead the detector achieves much more than the VDI.
The sampling routine should damp the signal a bit too much. But only Holyuser can answer ...
Hugo
eduardo1979
Le agradeceria que me ayudase en la creacion del IDX si no fuera mucha molestia envieme un mail a abellaire@hotmail.es y asi usted no tendra que mostar su mail por el foro y yo podre mandarle mis dudas por email.
Gracias de antemano.
Lo siento por la gente del foro pero no se mucho de ingles.
Hello eduardo1979.
I need help that me send for e-mail the scheme, pcb and necessary components to fulfil the complete idx besides the discrimination for 2 tones. Him agradeceria that was helping myself for e-mail since I have to translate everything what I write with a translator, and seeing that you also are Spanish for my serious easy for e-mail.
My e-mail is abellaire@hotmail.es
Thank you very much in advance.
I changed U3 to lmc6484 to lf347n. It so sensible. I changed the r25 too a trimmer. So I can adjust for more sensibility. A hungarian "20 forint" http://www.hamispenzek.hu/hamis_fempenzek_forint/20%20Forint%201994%20hamis%20hamisitvany.jpg comes from 40-45 cm. :-) Waohhhhh! It is fantastic... But! The of-key sign frequenter. I set up down the sensibility.
Originally posted by szucs_g View PostI changed U3 to lmc6484 to lf347n. It so sensible. I changed the r25 too a trimmer. So I can adjust for more sensibility. A hungarian "20 forint" http://www.hamispenzek.hu/hamis_fempenzek_forint/20%20Forint%201994%20hamis%20hamisitvany.jpg comes from 40-45 cm. :-) Waohhhhh! It is fantastic... But! The of-key sign frequenter. I set up down the sensibility.
