IDX-PRO+VDI
  • nice work, orbit
      [ATTACH]21903[/ATTACH]
      Nice! Do You integrate the 2tones in Your SMD forming PCB? This can be the good idee...
      • Hi, I`m building concentric 240/120mm diameter coil right now, and I cant null the coil. I have noticed some dependence: When I have 2 beeps for color metal for example copper coin I could null the coil with proper phase shift and voltage. When I swap rx wires to get 1 beep the amplitude of Rx and phase shift changed like this:http://w866.wrzuta.pl/obraz/3hrxNU89srx/phase, What I do wrong?
        • There is a little residual coupling between Rx and Tx a bit out of phase that in one case works opposite than the other. In both cases it can be balanced out, but not at the same angle.
          • There was mi schematic with CD 4077 two tone discriminator.Work better than id-pro.
            • Hi,
              i have build the Lugatek VDI kit for the idx pro. It works fine, but there is a counter integrated. He counts backward from 500 to 0. What happens at 0 ?
              Does anyone have a code without this counter?
              https://www.youtube.com/watch?v=C6kZ...s&feature=plcp
              • Hi, everybody! Collected VDI on Pic16f690. Consumption 0.33ma.It is correct?Sorry my English...
                • Originally posted by ahmad View Post
                  Dear freinds , i connect the lcd but i only see this !
                  whats the problem ?
                  [ATTACH]21832[/ATTACH][ATTACH]21833[/ATTACH]
                  anybody?????
                  • What is the right phase shift in concentric coil 90 or 180 degrees?
                    • My machine
ID:	333957Click image for larger version
ID:	333956Click image for larger version
ID:	333958Click image for larger version
                      Everything except pure range of VDI works fine.
                      Special thanks to
                      Eduardo,Ropcsika for help.
                      • Originally posted by reiv View Post
                        My machine
                        Nice work
                        P.s. Banan...
                        • Thanks
                          • Hi, nice work !!! here are some pictures an videos from my IDX Pro, but without Button label
                            https://www.youtube.com/watch?v=qfcH...&feature=g-upl
                            The idx is a very good detector, but i believe the disc could be a little bit better !! when i search with my idx on field there a many faulty noises from the DISC when he detects iron! so is it possible to improve the disc ?
                            Firebox
ID:	333969Click image for larger version
ID:	333970Click image for larger version
ID:	333971Click image for larger version
                            • Originally posted by Firebox View Post
                              Firebox
                              Hi Firebox,
                              I have some questions for you:
                              1. Why does your IDX-PRO have a label on the handle that says "Pulse Star III"?
                              2. Where did you buy the nice control box that is under the handle?
                              3. Where did you buy the triangular section telescopic stem?
                              • Hi @Qiaozhi
                                the case for the idx is a german Eurobox:
                                http://www.reichelt.de/?ARTICLE=5043...FVC7zAodm2IA9A
                                The Label Pulse Star III is on it, because the Detector shaft is from a manufactor which builds PI Detectors. But you can buy ONLY the Detector shafts from this dealer
                                http://www.tb-electronic.de/start/index.html
                                so this is the answer of your question 3 too
                                Hope you like it. On youtube you can see more of my projects for example Lugatek VDI an Geotech VDI
                                Firebox
