Gold Scan V Schematic
    My "other" hobby is electronic music synthesizers (wrote a Sams book years ago).
    So what's so special about the audio vco behavior?
      hello bklein......the Wowwwwww for iron and the Weeeeeeee for gold o silver !!!! produced by GS5 vco
        I have read that GS5 is at least 90-95% the same with TDI. If so, then this schematic is not from GS5. But i must thanks to Elbombaci for this schema.
          Doesn't "Wowww" and "Weeee" aptly describe just about any VCO as it slews lower or higher in frequency? I think so.
          What we need is a VCO that can work with a bipolar input voltage, or some way to offset the output from the final amplifier.
          Geo, this definately looks like an Eric Foster project and I'd be willing to bet it is the GS5, but for missing the last page. The GS5 Operating Instructions does mention a couple of things not shown on this schematic, but the schematic here looks like a pretty good start.
          Thank you, elbombaci.
          edit: 6666, I think that the 470Ω resistor won't work. 47Ω would be correct.
          edit: One more thing, the audio should get louder no matter whether the VCO swings higher or lower.
            For the sake of simplicity, when the audio tone rises, this was described as a WEE. When the audio tone falls; a WOO.
            Goldscan 5 either does a WEE, or a WOO and only rarely, both.
            A WEE indicates a target that has a faster decay than the iron mineralised ground. This would include most small and some medium nuggets. A WOO, indicates a target that has a slower decay than the ground.
            From the handbook
              Any chance for a PCB?
              Seem promising.
                I think "VCO GS V" could be similar to "GS 4" but with two channels for processing positive and negative signals separately, with different tone oscillators, which eventually would be added in the audio amplifier.
                It's just my opinion.
                  Seem promising.
                  1. promising if there are desoldered PCB photos in HD (High Definition) resolution or scan 600 dpi of the both sides.
                  2. promising if there is a full Part List. all resistors and capacitors are due measured.
                  now you see only a picture like a blurred mirage of the blue water source with palms in a desert.
                    What I see missing.
                    The input to the CD4001
                    Gb/disc switch (only a label showing)
                    The gate inputs to J113's on page 2
                    Missing 1/4 LT1114 opamp
                    VCO
                    Audio output amp.
                    If you search the findmall pi forum. Eric talks about designing this circuit
                    and and how he was improving the audio section over the GS4.
                    I agree with Alex and Jose, the missing parts are important.
                      so some forum that we send that we send how would they by pulse scheme for star 2 praised the to have scheme for TDI whites and when I sent the data za ps 2 I asked ,only VCO scheme tdi whites , and not no answers at least two words and now you ask in what is
                      goldskan 4 evolution
                      that I am at elbombaci would anyone no piece sematic some which are as honest and character people ...some would take all and that no nothing to give disaster !!!
                        http://www.analog.com/static/importe..._8052_8054.pdf ad 8054 see power this circuit ic , and what will quadruple amplifiers
                          Do you GS 5 has a resistor in series with the winding coil ? As has SL TDI Whites ![IMG][/IMG]
