Originally posted by Carl-NC
View Post
The fast changing magnetic field induces currents in all conductors within its reach.
These currents dissipate by converting into heat due to the resistance. In other words, there is an energy transfer from the TX to the targets.
Big targets like salt or iron ground, a large alu kitchen foil or a 1ounce silver coin absorb a significant amount of energy.
When we look at the peak Flyback voltage when we approach the coil to such a target, we can see tens of Volt difference caused by the target, showing the difference of peak coil current.
With a traditional PI, the TX coil is charged and fully discharged at every cycle. Any loss in peak coil current remains limited to each cycle.
With the bi-polar square wave, the losses add for consecutive cycles. Like a loss of 1mA for a single cycle adds as 100mA for 100 consecutive cycles.
Below is the circuit I used to measure the difference in the peak Flyback voltage. At post #1 of AMX RX.
https://www.geotech1.com/forums/forum/projects/active-projects/amx-project/408950-amx-rx#post408950
