Originally posted by Willy Bayot
View Post
7. No need for heatsink over the damping resistor since there is NO damping resistor at the XMIT level. No heatssink over the MOSFET's if low RdsON.
Condtions under which this circuit should work:
- All MOSFET's should be selected for a MINIMAL RDsON
- The two main switching MOSFET (on both sides of the coil) should be selected with a MAXIMUM VDS to sustain the high flyback voltage without avalanching. The other MOSFET's can be low volatae type.
- The small capacitor making the resonant circuit with the inductance of the coil should also be of high voltage type.
- The two triggering signals should be strictly complementary and preferably generated both by hardware and not complemented by software (if both ON at the same time--> BOOUM)
- The two triggering signals should have a dead time at each side. The dead time duration should be set depending on the switching speed of the main MOSFET's
