Not exactly. We had some discussion on wireless headphones, but even those tend to come with a quirk or two. Analogue are prone to interferences, and not fancy at all. Digital are prone to delays, and often variable due to retransmission.
Separating a main box from a coil would require a coil to have many functions included. It means you can't have a big battery there, so it must be low power. Also the communication link must be low power, which means the information going to a main box must be heavily digested, and the coil circuitry must have some brains on its own.
Communication link must be slow, and with constant bitrate. Hence the most of signal processing must happen at coil side.
As an amateur, I'd rather spend my time chasing targets with a more simple solution, than waste my youth on designing such a monster. It makes for a nice gadget though.
Having batteries in the coil can be a pain if they go dead and have to be in a waterproof compartment
That's the elephant in the room for the XP Deus. What seems [at first sight] to be a really cool solution, has implications later on in the product's life. Also, purchasers of second-hand Deus machines need to be cautious, as there's no way to replace the battery when it loses the ability to recharge.
Didn't knew that about Deus batteries cannot be changed when they go out. What to do with coil after batteries go damn? Simply, i will use my lovely tool from garage, his name is hammerhead.
The Deus coil LiPo cell can be replaced quite easily, and it's not too expensive either. And due to battery technology improvements, it's possible to fit a new cell with noticeably more capacity than early Deus models had. What concerns me about it is how critical the position of the cell is, I can't help thinking if it's 5mm off from where it should be, might the coil null be upset too much?
This is what is says in the Deus user manual: "The search coil battery is sealed for obvious reasons of safety and impermeability. It must be returned to our service department or an XP distributor for replacement."
It also says "The LiPo batteries are designed to bear hundreds of charges and to last several years in your detector, thus resulting in significant savings in terms of purchase of batteries. After 300 to 400 charging cycles the battery still has 80% of its capacity, which then gradually begins to decrease over subsequent cycles. As an indication, the batteries should last for around 3 to 4 years when used on a weekly basis. Attention: long-term storage of discharged batteries may reduce their overall durability. If the detector has to be placed in storage, First charge the batteries to half of their capacity (40 to 70%). Ideally you should then discharge/recharge them at least once a month."
OK - thanks for that.
So it's not impossible to do, but also not that easy. The best video is the one on the XP website, where they demonstrate the battery replacement using a Deus Battery Kit - costing 45 euros.
Watched the video. Yep not really a user replaceable part then. Doubt you will be able to get the connector or cover off as easy as in the vid.
Something I would tackle but we now live in a society where some people have to pay someone to change an ordinary plug
As for nulling as its away from the center of the DD I doubt the null will change very little as long as the battery is the same size a few mm out will still work the same.
