I had a problem my Golden Sabre(original factory built) beeping randomly when I would flex the coil cable where it entered the connector housing. I opened it up expecting to find a broken wire but there wasn't one. Looking close, however, there was an extra unused black wire in the cable and it looked like the strands of wire at the end were touching one of the receive coil wires. I cut the cable off and resoldered all connections and taped back the extra wire. I also connected the shield drain wire to the tab connected to the body of the connector. It only went to the middle pin of the connector before. Problem solved. No more beeping when I flexed the cable.
Merc
Merc
