Originally posted by Fred
View Post
I had a bad gnd connection at U7... due to solder on top layer... after fixed that device started working somehow but very bad...
1 eur coin at 20cm but sound is very bad... chatters always present ...it's unstable and noisy.
I followed signals but just relevant anomaly is that U7 has on output at pin7 something 9Vpp@50Hz , that's huge amount of sinusoidal noise!
Let me explain... I found that at U4 I can trace the introduction of about 20mV noise at 50Hz that then propagates and is amplified by following op amps along the chain... so I end up with 9Vpp at U7!
Now the problem is... the coils are shielded... and I'm using a very low ripple powersupply... so where's that dang 20mVpp noise enter the PCB ??? Where is it from ???
I haven't fluo-lamps there... I haven't anything that emits strong 50Hz radiations... but my dubt is device is so sensitive that source of noise is probably farther than I expect to be.
Another consideration is about decoupling caps... I still haven't them on circuit... so maybe the problem could be there...
Kind regards,
