RELIC HAWK
  • Hi,
    Hush.
    Thats interesting but there are few caches here.
    Basicly Musketeer and Relic Hawk are almost indentical and coil from musketeer should work with RH if pin compatible.But dont forget one thing Musk is average model and RH is TOP.
    And at first place what unit you use to took this measurments?
    I have to buy myself some good inductancemeter and solve this finaly.
    The major probleme is that there are some conections under ICs that cant be seen.All have to be desoldered.
    Once we have good working PCB the coil will be easy part.We have experts here.
    Anyway thanks for shared info.
    p.s.More usefull would be if you can took some pictures on Musketeer PCB.
    • Hi Tiktak. I agree with you at all points. Don't know RH connector look like but it's easy to buy Musk connector and resolder coil wires, if it's useable. Didn't meen to make some confusion here, just to help if I can. Measurement is done with unimeter UNI-T UT 70 A, not bad at all- you can measure between all, freq to 10 MHz,inductanse, etc. My PCB isn't paint like some other Minelab's PCBs , it's clean,so I can make pictures but as I see you have very good pictures here.If you need some, I can do it.
      Regards.
      • Hi
        Hush.
        I will be very greatefull.
        This will help me to see some conections.
        • Relic Hawk work 100% with Musketeer coil.
          At the moment my copy of relic hawk work with 10" coil.
          Only have a problem with discriminate big Iron from long distance.
          I think ,the problem is in shematic
          Some ideas?
          • Hi
            I am glad that you mannage to make it.
            So you see that Max have almost made it only with faked schematic.
            I think that I found this last mistake but I have to check again.
            I will let you now.Because I am still working and you are ready.And can check this right away.Can you make some pictures on your RH and post them here.
            I am interested to see swithes wiring etc....
            • My copy of Relic hawk is Coinseeker2pro
              But I make some changes in shematic and work now
              very good.Only problem with discriminate big Iron from long distance
              If somebody have good quality pic's of Relic hawk psb pls posted here
              • Hi,
                So frustarited now again.
                I could use some help.Still cand find right solution.
                Ivconic,
                Did you smashed your PCB?If not can you try something please?
                Now I now almost all parts.But still see diferances with Maxs work.This is because of the starting point.The schmatic.
                But some parts are just like on the original RH PCB.Hum.......
                We will see.Did you have a sketch on wirings under this WIMAS 1m 160V?
                Also fustration there.
                Fred,
                What is the point of ground pane on this side?Still some points dont make logic for me?
                Did you finish yours?
                • to N@SKO
                  Post it here so we can see?!?!
                    You'll probably find that no-one is replying to your requests because you haven't registered.
                    It's a very simple process, and it's FREE!
                    • Sorry
                      Have some bag of viruses here on this PC and I dont wnned to mess with my accounts now.
                      Tiktak.
                      • Bugging and harassing as usuall here, Tiktak!?
                        Asking again and again same old questions? Read posts and understand.Don't ask same question hundred times!
                        You are like pest, man simply must run from here, cose of you.
                        • OK.
                          This time I will leave forever.
                          And my hobby wont go away.
                          I wont post here anymore.
                          Still cant understand why I anoy you so much.
                          But anyway........................
                          • I am wondering isn't there some ICs mismatch here?
                            Could one of those 4066 actualy be 7400: Quad 2-input?
                            Because on Musketeer we have two 074.And here only one near ref.voltage.
                            Still so many missing spots here.I am wondering how Maxs unit work so good?
                            And in same time there is something so wrong.We wont have it soon.
                            Maybe realy ML stop making this because of far Iron detection?
                            • Originally posted by erolunall View Post
                              Hello
                              Unregistered schematics direct link is
                              http://www.snimka.bg/album.php?album_id=240227
                              Erol
                              Can you please tell me where you get this schematic from?Because I have a couple of questions.
                              • Originally posted by N@SKO View Post
                                каде остана Наско
