aaaa
  • aaaa
    pls i have schimatic of adonis system titanium
    My new detector, the pulse power VLF diskriminatorom
      "Your" !?!?
      It was made by Jackdetect - NOT by you!
      Let me see.... you have there Jackdetect's handmade, you have there broken GP3500 .....and you heve there "Caesar" copy ....hmmm!?!?
      I don't see neither one of your handmades there dude !???
      Maybe your "brother" from another topic took it? (and now he claims those as his own handmades...!?!?)
        Jackdetect's pcb from that detector....
          Jackdetect ...holding the prototype!
            Good friend of Montenegro. RIP. He post me an I/B detector made by him. I repost the schematic on this forum. But not the pulse power with discrimination.
              Not from Montenegro but from Serbia, Aleksinac city (Tesica village 6km away).
              And this metal detector has nothing to do with PI's. It is VLF I/B.
              Was my closest friend and i've been there at the time when he introduced his first prototype. He made dozen of those before passed away.
              This VLF I/B was projected as close to genial design. I was delited with it's performances. It has minor lacks easilly fixable. Jackdetect realized that and wanted to fix those minor lacks in next serie. Pitty he didn't had a time enough.
              As his close friend i feel much offended when see some scum reptiles here taking advantage of his work.
              I do have documentation of all his work. But in respect to his personallity and direct wish of his familly i simply can not post those in public neither to share.
              Not only that; i simply do not intend to use whole design nor even a part of his works.
              This detector was completed as His own original design. Some of the principles are used from some Fisher solutions as model only.
                In the preliminary design is djekdeta but this detector has no connection with these mild detector because I am 50 per cent had to edit that would finally get the detector that really worth the guys they all know that after cesar mentioned this could mean that some table were logged under two names and itri the geotechu and make that the brightest of all and put all their texts, and all are mixed and have not made a single detector in life.
                  Drugo ovo sto vidite je samo spoljasnji izgled a u saglasnost sa njegovom suprugom sam i preuzeo neke njegove ideje da bi bas iz tog razloga sto je ima puno nedostataka da se to ispravi i da konacno dobije zeljenu formu pa ako ste bili prijatelj sa Zeljkom pozovite njegovu suprugu Adrijanu i uvericeiete se u to . postovane sveznalice.
                    What was that??? "Eastserbian English"!??
                    Despite your illiterate use of some online translator i think it is good enough to understand what you wanted to say.
                    So you actually are saying that Jackdetect's design was very bad UNTIL you came on "scene" and fixed all the lacks and improved it?? And you had to change 50% of it to make it work!?!?
                    Ha,ha,ha!
                    Look dude, don't mix in things you are not able to hold.
                    Do what ever you do but do not come here and talk nonsences and lies.
                      Write it on English.
                      I will call Andirana to check your claims.
                        Thanks for clarification! Yes, I remember that he wrote me about spare time in Montenegro... forgot this detail. Very decent person. I sorry his loss of this world. Their treatment was right toward the people...
                          Ha,ha,ha!
                          This is the result from my translator, although some of it didn't translate proprly:
                          Secondly this is what you see is only external appearance and in agreement with his wife and I took some of his ideas that just for this reason it is there are many shortcomings to be corrected and to finally reach your desired form and if you were a friend to call his wife, Zeljko Adrian and uvericeiete in it. Eiko wiseacre.
                            Agreement between me and Adrian was about to continue the project was not completed and had a lot of shortcomings in terms of the impact of the country and in a small range of disk mode, etc.. And that when completed is presented to the public so that finally got everything what are the requirements of a good detector. Just do not keep you ignorant of the famous masters of the Montenegrins. Just as I doubt that you are from Montenegro.
                              "Not completed"???
                              He already made and sold dozen units, how is possible to do that with "not completed" detector?
                              Some of those detectors are still in wide use. Working extreme good. I tested it several times, i went to sites with it, i founded much items with it already. So?
                              I will check with Adriana your claims soon.
                              Also;
                              your first post where you showed photos - i don't see you explaining which idea and product was that detector and how you got it? ( i know you exchanged it with other guy, detector was broken, had some minor fault at audio stage - common fault at those detectors).
                              Also i don't see your explanation in your first post here - same explanation you gave now in your last post, pressed with facts i posted?
                              All i see in your first post is " My detector..."!??
                              I am not from Montenegro?
                              Who told you that???
                              You do not understand English well and now you mixed up everything!?
