LOOKING FOR GOLDSCAN 4 Schematic.
  • #61
    Hi! VLADIMIR
    i am wanted make gs4 for that i need your help
    Send for me too please.
    Thanks in advance
    jamal ...
    • #62
      Hello. needs your help ... Carried out and this system is not working as it should. I know about errors in the J113. What else can be bad for PCBs? This is the work of Alex.
      • #63
        Hello
        after all these discussions, does anyone have the correct schematic of GS4 ? or knows the errors in current schematic ?
        I have one Proteus ISIS designed schematic contains PCB. and one another.
        • #64
          GS4
          hi hesamavr
          can you send to me schematic designed contains PCB. for gs4
          thank for you
          jamal
          • #65
            Hi Vladimir
            May you to post it to my email???? sinko1@abv.bg regards
            • #66
              GS4..
              hi max AND FRIENDS
              I'm sorry because I was pouring from you during that period. Because my work continuously gs4, now all electronic wiring ready, and I am prepared to a key combination, but I have a question about (sw1) are you properly used three separate keys, or three keys integrated in one piece.
              thank my friendS.
              jamal
              • #67
                Hello
                jamal did you find something good as a switch? (SW1). I think that should be OK
                • #68
                  I explained before, already
                  • #69
                    sw
                    thanks for my friend ,inio 01 & max
                    I wish good luck for your.
                    jamal.....
                    • #70
                      hello Jamal,
                      This is the switch you see in the photo from inio01
                      • #71
                        power supply
                        my friends
                        I have problem with power supply circuit , output
                        voltage is (-6.5 , -1.5 , +4 )
                        but when make test for (7912 )it is ok.
                        note:
                        1- I connect circuit POWER SUPPLY
                        separately from main circuit
                        2- my friend tell me must be exist center tap for a achieved the GROUND POINT , but your are know that it need AC power & ( transformer)
                        pleas tell me where is the problem
                        jamal...
                        • #72
                          pleas
                          jamal...
                          • #73
                            problem
                            jamal...
                            • #74
                              power
                              the circuit power supply for GS4, consist with general circuits power . look regulator 7805 .
                              http://www.datasheet4u.com/
                              • #75
                                power
                                this
