My Digital Pulse detector Delta Pulse 3
Hi again,
I see that the coil i have received in kit , has 2,4 ohm. So I have to put 5w1rj resistor, it´s right?
If is like this, I have a problem, because two cement resistors i have received are 5w2rj and i´m trying to find 5w1rj but i don´t see anywhere in web.
Can anybody say to me where can i find it?
Thank you very much.
-You can experiment :-
1- without .
2- with one .
3-with two resistances in parallel .
And see the result
****the true result that when does not display the --coil is not Connected--****
best time
j.
Hi, I have a question. My DP3 is working ok, but i don't understant the purpose of the two LEDs connected to the 4094. I have seen on a frontal posted something like "FERROUS" and "NO FERROUS", but by LEDs are always off.
Should they light when something is detected? There is something wrong with my circuit?
Thank you
Originally posted by DianaBlu View Post. My DP3 is working ok, but i don't understant the purpose of the two LEDs connected to the 4094. I have seen on a frontal posted something like "FERROUS" and "NO FERROUS", but by LEDs are always off.
-May be the two LEDs connected wrong.
best time
j.
Originally posted by hadi-dindar View Posthi to all friends
i want to print the pcb of dp3 on board . but the size of this pcb wrong.
i cant match pins of pic with pcbs pins . plz send me correct pcb for print on board.
regards .
DeltaPulse3PCB 16.5cm x 11.5 cm.
from pdf print true size.
best time
j.
regards .
Hi hadi-dindar
Print the PCB with scale 100%
Best time
Nicolas
