Simple Russian PI detector Pirat
  • #91
    http://www.chipinfo.ru/dsheets/ic/157/img/157ud2-2.png
    • #92
      I found you some to buy dont complain about the price
      http://www.ebay.com/itm/K157UD2-IC-L...QAAOSw7U5Y-cx3
      • #93
        It is for 3PCS so still acceptable in big need.
        • #94
          Yep 3 pcs, interesting thing about the advert is it says equal to LM301
          • #95
            Truth is a pile of Op Amps would fit the bill and do as good or better.
            • #96
              How can i open .lyt by the way? Google says Xcalibur , is it freeware?
              • #97
                It is not freeware.
                You need PROTEUS-ARES ...
                https://www.youtube.com/results?sear...y=proteus+ares
                • #98
                  Thanks, but this isnt freeware too.
                  • #99
                    Try this. It works for .lay files. Try to change the file name to .lay and open. en.freedownloadmanager.org/Windows-PC/Sprint-Layout.html
                    • This doesnt seem to work. But i finally got the Proteus ares.
                      • I finished my K157ud2 version , but my K157 has not arrived yet.
                        I saw that only 8 Pins are used at the board. Is it possible to just connect the pins from the TL082 to the 14 Pin socket?
                        If yes, which pin belongs to which socket pin.
                        • i have them killogramm. with a bara board i will send you it for free =))))
                          new rule. whom order Bara will get 157UD2 free and DVD with archive 4 GIGIBAIT free.
                          • I did one of your boards. Good times to be had. All Running just waiting for a Housing for the thing. Thank You.
                            • i will send the board with George's/Quazhimoto's mod done. if you have 40106 broken then make that too.
                              • Nothing Broke on this board. Running just fine. Just need a nice Box to put it in.
