TESORO GOLDEN SABRE
  • Horseshoe? No, not discriminating totally. Beeps with spits and cracks.
    • So my point is when I swing this horseshoe around cross points of TX/RX winding,I can hear sound like for good target.Is this normal?
      All coils so far couldnt be null below 0,2.
      Now I have print the former that were posted here in PDF format.To clear former size and shape question.
      • "..So my point is when I swing this horseshoe around cross points of TX/RX winding,I can hear sound like for good target.Is this normal?.....
        It is normal.
        • Now its look like everything is like it should be.
          This iron detection were bugging me.
          So I should try to fine tune my best coil so far.I should monitor only rx signal with oscilloscope and look for smallest reading possible.Right?/rx not conected to PCB in this procedure/.
          But this way I wont be able to monitor TX/RX faze shift.
          I were using ch1 2n2907 collector and ch2 353 pin7 and multimeter in same time conected to 353 pin7 so I can look for smallest reading in same time.
          But with this way RX is conected to PCB.
          What is your advice?
          • about tgsl
            mr ivconic
            there is a diference in between tgsl schema and pcb.
            a 1n4148 diode,d13 as per sb schema,from anode of all the diodes around 4024 to gnd.
            can you explain the function of that?
            thanks so much(i am newbie).
            best regards
            • Originally posted by Ultimate_Haze View Post
              Ok,
              I just wanned to now.
              So I will scrap all and make new coils.
              Notice that I can thune RX buy adding some extra cap.lets say 6n8.And with this setup I see good depth.But when I test device its sensitive to hot rocks and iron in disc mode.Then it rely must be my coil....
              I now that no body can solve my problems from distance.Just getting crazy.Its simple device.Shouldn't be so hard.And I have made all with a lot of care and good will.
              Ultimate_Haze:
              How did you decide where to set your ground balance pot?
              • Hi,
                I leave it in middle position all the time.
                Think that this cant change depth performance in this moment.
                  Ok,
                  Hi Ultimate_Haze: I am trying to make same pcb so interested.
                  Can you answer this question: when you take detector outside and set sensitivity pot to most sensitivity, do you hear any noise chatter, or is it totally quiet?
                    Chatters can appear due bad coil also. Actually....in 99% of cases chatters DO appear due bad coil (at all pcb versions, i know that cose i made all versions so far).
                    • Originally posted by DEMAC View Post
                      mr ivconic
                      best regards
                      Stabilisation relative to ground. Especially efficient in longer traces case. Not obligatory, but good to have it too. If it bugs you - remove it!
                      Say... have you another nick here?
                        Still its not good enough for outdoor tests.But I can tell you that I can use sens. at max and no cheeters at all.This is indoor without shield on PCB.So I excpect that it will be even better later whent I mount in shielded box.Only this low maximum target detection.The best I can get is 24cm.For large 3.5cm coin I can get 30cm but this isnt 32 for 1E.
                        Wanna try SMT also but first have to make this one work like it should.
                          Ultimate_Haze, Ivconic: I think it would be best if max sensitivity always gives chatters even with good coil, then we can run it hot or pick amount of quiet.
                          If no chatter on max sensitivity, I suggest experiment - put temporary jumper across R37 (1K resistor from sensitivity pot to ground), shorting it out. Then max sensitivity should give chatter for sure, and you can test maximum depth knowing threshold is not part of the problem.
                          • Good tip.
                            I will try it ASAP.What is the status of your device?
                            Cheteer arent good!This way you miss deep or small value targets.Best md is rockstable.
                            Good luck.
                              At this specific case i do not agree. That's why we do have here GEB preset, if you want to run it "hot" than lose GEB a bit. But to have that handy - GEB trimmer must be replaced with multiturns pot, like it is case at Eldorado.
                              Same thing is at my Musketeer. When GEB is on Auto i get no chatters at all with max Sense. But if i want to run it "hot" than i manually adjust GEB.
                              So... what you are saying is maybe a case at some other model or brand, but it should not be case with TGSL.
                              So...how to know when coil is good (to U.Haze)?
                              Sense at maximum, All Metal mode, adjust with GEB to reject ferrite rod (5-7cm long and standard from some am/fm radio) and JUST to produce rare "cracks" on it. It must reject ferrite rod and accept thin silver coin at the same time. It is critical position at GEB trimmer. Than you should not hear any chatters at all. Also you may check air "depths". Usually 1 e coin at 30-32cm in air.
                              This is pretty accurate method to check if coil was balanced well or not.
                              If you hear no chatters and you are satisfied with air "depths" than you may lose GEB a bit to produce more often cracks on ferrite rod. Or you dont need - as suits you.
                                Hey! Dont do all that at the same time!!!?
                                Depends of your measuring instruments characteristics; but you may get some parasitic effects there, connecting all possible instruments to same pins!
                                Yes do connect both coils to pcb and use scope - scope LF353 output.
                                Or...use my method and disconnect RX from pcb and connect it to accurate milivoltmeter....(this only in TGSL case - not general rule)
                                Any measurement and scope at the time. Not all togather!
