Hello Wesam i don,t have the Barracuda on eagle but you can buy a Kit from Silverdog very high Quality and its very simple to built and with proper setting you get good detection range greetings from the harz Montains
BARACUDA-Legend-1
Originally posted by Vermeer111 View PostHello Wesam i don,t have the Barracuda on eagle but you can buy a Kit from Silverdog very high Quality and its very simple to built and with proper setting you get good detection range greetings from the harz Montains
but Is it safe to deal with this company?
or any body try to built this Kit?
yes its save my bara come from him,very fast delivery,you can pay via paypal,many members from the forum brought his kit from silverdog,very good quality,when you have problems with this kit you can ask the members in this forum,in my kit i have only a faulty 7660 (change with a good one and all is runnig)and 1 resistor (100 ohm)i have double in the kit,soldering on th pcb then make a coil then you have a good Metaldetektor greetings from tha harz forrest
Originally posted by Vermeer111 View Postyes its save my bara come from him,very fast delivery,you can pay via paypal,many members from the forum brought his kit from silverdog,very good quality,when you have problems with this kit you can ask the members in this forum,in my kit i have only a faulty 7660 (change with a good one and all is runnig)and 1 resistor (100 ohm)i have double in the kit,soldering on th pcb then make a coil then you have a good Metaldetektor greetings from tha harz forrest
Baracuda working
Hi Folks,received my Bara kit from Silverdog last week and finally got to put it together today. I must say hats off to Silverdog for this awesome Kit. Spent about 4 Hours on the pcb and then wound up a quick test coil ( 28t 9" form wire size 0.5 ) hooked up a 9v ni-cad battery for testing,adjusted offset,delay and threshold and bingo the Bara was picking up a Canadian $1.00 looney at 23cm
. Can't wait to see what the Bara will do with a fast coil and a good battery pack. Thanks to all on the forum for you input on the Bara, I read all threads several times sure helped in getting good results
Cheers.
LF412 is a dual opamp. LT1115 is a single (also TL071, TL081). They are not interchangable.
edit: Now, if you would be wanting to replace the NE5534 with LT1115, that might work. But whether it would work without having to make some other changes, I can't really say. The compensation and offset-null pin connections are about the same so it might work, but no guarantee.
Linear Technology does not give an example of how any compensation capacitor should be connected in the LT1115 datasheet and you should not assume that it would be exactly like the NE5534 connection.
Help power supply problem
Hi Folks, my bara has developed a power supply problem. with a 10.8v supply the -5 volt regulator 79l05 has around -2.5v on output pin,the positive regulator 78l05 is +5v. If I lower the supply voltage to around 9volt the bara will work but with low sensitivity and the -5 will come up to -3.5v. I tried changing out the 79l05 but no change. I'm thinking maybe the 7660 is defective. any thoughts would be appreciated.
Originally posted by wizz737 View PostHi Folks, my bara has developed a power supply problem. with a 10.8v supply the -5 volt regulator 79l05 has around -2.5v on output pin,the positive regulator 78l05 is +5v. If I lower the supply voltage to around 9volt the bara will work but with low sensitivity and the -5 will come up to -3.5v. I tried changing out the 79l05 but no change. I'm thinking maybe the 7660 is defective. any thoughts would be appreciated.
