If you were to set up the detector to accept a Euro coin but reject the pliers, I suspect (if you leave the settings unchanged) it will then also reject an aluminium soda can.
Maybe I'm wrong, but perhaps one of you can test this theory and report back.[/QUOTE]
Definately no! The delay adjustment is versatile you can select automatic delay or manual. And about the iron removal it is range in 0-30. 0 means discrimination is off and as 1-30 is your choice which metal you want to reject.. If you set it to just reject iron then you can and still get the aluminum, and if you set it to reject iron and aluminum then you can also. It easy to understand if you just have the machine on hand because theres a plenty of setting you can choose.
