to reg
you really need to change chip to offset?
I think RV1 hides other function.
I tell you how I think.
U12B is an analog memory, the voltage on TP6 is loaded in C29.
On pin 7 U12B I have a amplified voltage of about 6 times and this goes to R40 and R52 + SW1-A.
U12C is a comparator voltage between R40 and RV4 voltage, the comparator trips when it goes to -4.31 V and forbids FET Q10 and voltage at C29 can indeed be amplified (object detected).
In the event that no object is internal loop and in the presence of noise, U12C corrects, by sending into saturation Q10 (approximately +4.12) for a short time, and prevents noise to hear the speaker.
How do I connect this with my claim?
I checked the voltage on pin 7 of U12B and it is always positive, this makes sure that pin 8 of U12C is always at -4.31 V and then interdiction for Q10 and it does not work automatically.
What to do?
RV4 rule only negative voltages.
We must adjust RV1 so that we shift the voltage at pin 7 of U12B towards negative values so as to be able to operate properly U12C.
Everything you said is true Goldscan original.
Google translator.
What to do?
Google translator.
