King Cobra PCB
  • Schematics covered by the board.
    GMT:
    King Cobra
    GMT1650
    Gold Scorpion – most likely, no data
    Thunder Stick – most likely, no data
    1980: Deep Search VI, Deep Search IV, Deep Search VII
    1981: Aztec, Cortes, Amigo
    1982: Scout, Mayan
    1983: Inca, Silver Sabre
    1984: Sabre II, Sabre Supreme, Silver Turtle
    1985: Golden Sabre, Cutlass
    1986: Silver Sabre Plus, Eldorado, Royal Sabre
    1987: Toltec 100
    1988: Toltec 80, Diablo, 4 Reale, 8 Reale
    1989: Golden Sabre Plus, Lobo
    1990: Bandido, Pantera
    1991: Diablo II, Silver Sabre II, Stingray, Laser B1
    1992: Cutlass II, Golden Sabre II, Laser B2
    1993: Bandido II
    1994: Toltec II, Sidewinder
    1995: Piranha, Stingray II, Laser B3
    1996: uMax Bandido, uMax Cutlass, uMax Diablo, uMax Sidewinder, Amigo II
    1997: Shadow X2, Lobo SuperTRAQ, Laser PowerMax, Bandido II uMax, Silver Sabre uMax
    1998: Cutlass II uMax
    1999: Sand Shark, Laser Rapier
    2000: Conquistador, Compadre, Golden uMax, Tiger Shark
    2001: Cortes, Conquistador uMax, Eldorado, Euro Sabre, Silver uMax
    2003: DeLeon, Tejon
    2004: Cibola, Vaquero
    • ok I have everything KT for the small value caps in 50pf can I go with 47pf 50v or should I use 51pf 200v or is this going to cause an issue ?
      • Originally posted by calebsone View Post
        '50' typo nominal value is American standart (from USA that had been spreaded in Taiwan, China and Japan). in our part of world we have 47 and 51 and no 50. both 47 and 51pF will be OK. main rule in electronics is that the caps' voltage value has to be no less than power supply voltage plus some reserve. for /+8-8/=/16/ we have to choice 16+X, ie 20V and 25V caps. 50V and 200V will be OK.
        all the best
        • all files are reuploded for new members http://hidemyass.com/files/FTj4L/
          • http://www.findmall.com/read.php?17,...83#msg-1080183
            thought may be I have to add Tesoro's Golden Sabre Plus to the list according Monte's info.
            Tesoro's Golden Sabre Plus. The Golden Sabre didn't have the dual tone. The Golden Sabre Plus had the dual-tone audio, like the Royal Sabre, and also operated at 15 kHz (Tesoro's info) which was the same as the King Cobra.
            Just remember that you run the risk of damaging a detector and the value is almost zip.
            I'd simply tweak the GB trimmer for the worst ground where you're likely to hunt, then go enjoy the King Cobra. I worked with a lot of King Cobras as a distributor, mainly working moderate to highly mineralized locations, and once I tweaked it (not TOO positive, just slightly) I NEVER had a problem.
            Monte
            GMT:
            King Cobra
            GMT1650
            1982: Scout, Mayan
            1987: Toltec 100
            1993: Bandido II
            2003: DeLeon, Tejon
            • KT I found a whites concentric for 14 on ebay is there any way to make it work for this detector its called a 4b. its 6 something kh I think
              • GMT is working with a coil without capacitors inside, both on TX side and on RX side too. that is Tesoro type coil. I have no data on Whites 4b type, but thinking Whites always made coils with the capacitors inside. I do not suggest you, but you may open it and desolder the capacitors... 4b type has oldie 'omega' windings/balancing configuration IMO.
                • I just thought id get lucky but no biggie I keep looking or just make one thanks I have a very blurry finished board pic but when i find the camera cord they'll be right sorry
                  • looks nice! there is some SAT instability in ALL METALL mode, people write me in PM about, but I hope to search the trouble as soon as we will go to summer here.
                    • TESORO 8 1/2" Wide Scan Search Coil --- 5 Pin Connector, at low price. may be applicable... have not full data on the coil.
                      http://www.ebay.com/itm/TESORO-8-1-2-Wide-Scan-Search-Coil-5-Pin-Connector-/251256929099?_trksid=p2047675.m1985&_trkparms=aid% 3D444000%26algo%3DSOI.CURRENT%26ao%3D1%26asc%3D13% 26meid%3D6845187440606117495%26pid%3D100012%26prg% 3D1014%26rk%3D3%26sd%3D251235072430%26#ht_2221wt_1 129
                      • Keith sells a coil if you have a trouble on it http://compass-metal-detector-forum....td7588112.html
                        • What is the maximum depth at which a metal will find
                          • Originally posted by starmoml View Post
                            http://www.losttreasure.com/content/...ntain-gmt-1650
                            http://www.losttreasure.com/content/...ain-king-cobra
                            • how could it be otherwise, no problems, the disc position metal detected, but only to a maximum of 5 cm (two ton),all metall position no metal perception, have the switch cable checked, all in order, would be a wonderful if times times what works directly
Name:	2013-04-17 17.26.07.jpg
ID:	335874Click image for larger version
Name:	2013-04-17 17.27.37.jpg
                              • what type you use Q1 and Q11 transistors? I see they are soldered inverted. main rule is all resistors have to be measured before to be soldered, even you are confident in its colour code.
