blisstool ltc64x v2i
  • Originally posted by kamdox View Post
    fact that Blisstool ltc64x v3 has perfect discrimination of iron. Anyone who has used this machine knows that.
    Maybe, but not so on your videos.
    Perfect discrimination of iron mean no signal on iron targets, something that was not seen on your videos.
    Seems that Blisstool cannot perfect "discriminate" even surrounding soil and air not to say iron.
      But anyone watching these videos needs to be aware that there can be a big difference between a demo and actually using the machine yourself. With the sensitivity / gain reduced to a usable [sensible] level, I suspect the depths will be more realistic, as shown in a chart someone posted earlier.
      In my experience, there is not much difference. With my Blisstool I achieve even better results, but it is V3, which is better than V2 and V2I. To stabilize the detector, I mainly use the silencer and the threshold but please note that whenever I can, I work with gain max or near to it, and this is almost always
      • Originally posted by joop View Post
        Okay, one more time ... I will try to translate it literally...
        All of the objects are buried years ago next to iron so it resembles reality, because tests in clear soil always have greater depths.
        Before the test a large 7 cm. long nail is discriminated.
        These tests should not be used when buying a detector because in other types of soil values will be different.
        It does not say what kind of iron is buried next to an object.
        Thx for your help - I will translate it now so everyone (even me ) has the plain info:
        The buried close to iron has nothing to do with the 7cm nail.
        And we don't know what shape, size and distance this iron has.
        And the nail is used to set all the different detectors to the same
        "discriminate 7cm iron nails" level only.
        This means the german (or still belgium?!) detector test doesn't
        use allmetalmode at all which gives for shure 20-35% more depth.
        We really need to know all those facts much earlier.
          I am not interested in video tests but from my personal experience with different machines. For me, perfect discrimination is the fact that with Blisstool I do not dig iron, if I do not want this. I easily distinguish it. It seems that in your virtual life you have other criteria
            I know, that you are not interested in real test, cos your "bliss" cannot pass it.
            My criteria in virtual and in real are the same: detector should not detect surrounding soil and air, as blisstool ltc64 do.
              but at least
              now with the depth improved v3 those values haven't changed:
              http://blisstool.com/index.php?optio...mid=96&lang=en
              I follow this long. I think these data refer to Blisstool ltc64x V1 or Blisstool ltc64x V2. V3 is better. Here is the description of the different versions announced by the manufacturer:
              http://blisstool.com/index.php?optio...tid=23&lang=en
              I have direct experience between V2 and V3 and confirm these data.
              Personal test 1 Euro (23mm):
              within close living-room electricity @ air:
              threshold 0: 18cm
              threshold 3: 22cm
              threshold 5: 27cm
              However under good conditions outside threshold 8-9 is no problem and could result @ 33-36cm (not tested yet)
              I am surprised by your incompetence in this case. Blisstool not work well in a room with interferences. I learned this long before I read its manual. In ground it easily detect coin 23 mm of 36-45 cm depth depending on the soil and on the exact Blisstool version (this refers to the model ltc64x).
                As seen on videos ,Blisstool work with interferences (detect soil and air) in open field too.
                This is real problem, not how it work in room.
                  I can understand what the reason for this type of test is. In Germany/Belgium and the Netherlands, Roman and Medieval habitation sites have lots of iron. The challenge here is to find interesting objects between all the rusty nails. Searching in all metal mode will make you nuts, even if you can hear what is iron and what not.
                    I think it is clear to all that your virtual experience is not valid in reality. A word of advice, stop watching video and start practicing the hobby into practice , but not only with White's M6. It is good only for your room
                    You tested in reality blisstool machine? No. Given this, I understand your ignorance on the matter, but it is unfortunate that you are so deluded after you had any claims in this area.
                      Big words of big scammer.
                      Even virtual experience is enough to conclude (out of your video) that your "bliss" detect a crowd of ghost targets in soil and even in air.
                      And that you avoid real tests. Prove that this is not true.
                        My trip went well, as usual, always, but your humor shows your ignorance considering the fact that Blisstool ltc64x v3 has perfect discrimination of iron. Anyone who has used this machine knows that.
                        You are recognized, Ahmed Merchev!
                        Why hide anonymous? Maybe you ashamed of yourself?
                        You think yourself very smart, registered as plain user to make your spam.
                        This is not behavior worthy of inventor and manufacturer of metal detectors.
                        • Originally posted by holyuser View Post
                          HAHA! Again you are wrong. It seems that this is your new conspiracy, you're not just funny, you're pathetic . This topic is full of your ridiculous statements, and now is not your comfort, that I demonstrated your incompetence on this topic . I'm just one Blisstool user, who read your crap and decided to share practical experience on the topic.
                          Personally for you, I think that you're just an amateur who wants to pay attention, but it is ugly you can do it on the back of someone else. As I said earlier, I am sure that I am personally contacted with you in the past, so much better I know that you're not what you want to be, unfortunately . No self-respecting man, especially with claims for professional experience and wisdom, not behave like yours demonstrated in this topic. Do good if you want someone to take you seriously.
                          It seems in this topic I am one of the few with experience with Blisstool , so I know what I mean. I have not virtual observations as you, but real observations. I'm interested why you and WM6 are so end in this topic. You have not personally tested Blisstool machine and your comments contain false information, possibly deliberately . Try to refute some of my statements about my Blisstool V3. You can not. Only empty words. I wish you enlightenment in soon. This is in your interest.
                          Pity that there are people whose sole purpose in life is to harm someone else.
                          • This is a technical forum where people gather around technical issues construction or repair of metal detectors. Any type of marketing does not have much success here... Best regards.
                            • It seems Kamdox is really Ahmed Merchev.His way of writing much like writing in Bulgarian forums - no mistakes,often mention the name Blisstool v1,v2 or 3 .99% sure -this is Ahmed Merchev.
                              • Does someone who owns of blisstool will show a true test?Is it so hard,or it's just impossible?
                                According to the first video,blistool can detect a 13'' deep coin between nails.
                                http://youtu.be/CHHeGLU7VnU
                                German test says "no way" even for much bigger coin (close to iron),at half of this depth.
                                On the next video - at first there's no signal.And after increasing the tresh. the detector became unstable.
                                http://youtu.be/iXjy0moYhqE
                                Gosh this guy can dig a hole from here to China,and still there will be something like signal.
                                Does he knows what is "hole effect"?Look at 1:53 and 2:11 Even a slight touch of the coil creates a beep.
                                http://www.youtube.com/5ekQpeJYg_Y
                                So the sceptics here still waiting for a proper test.
                                As Matt says
                                "If you wish to prove your machine, then do the following:"
                                1 Dig the hole to 13 inches.
                                2 Place your nails in the hole.
                                3 Video yourself setting the disc levels such, that there is no response when sweeping the hole.
                                4 Show us the disc settings, and all gain settings.
                                5 NOW place coin in situ with nails.
                                6 Re-sweep and convince us sceptics.
                                7 Please sweep at a rate relative to human usage, and not robots.
                                +Do a complete swing,like in real search .Do not move the coil only over the signal
                                ...thats added from me
