Barracuda Legend Kit Problems
  • Thanks, I'll try.
    I noticed that when the switch SW1 is turned off, the detector reacts to metal but when I turn on the switch detector only humming, I Shrunk the potentiometer Work to an end, the sound is gone or does not respond to metal.
    • you have to learn that is mean 'double field coil' and 'basket coil' matter. try SEARCH engine of forum.
      • Originally posted by crni1 View Post
        Sorry.
        I use Google Translate and is therefore error occurred.
        Yesterday I finished barracuda, he immediately started working satisfactorily.
        I noticed that responds poorly to gold, I returned Delay and managed to grab the gold from 3 grams to 15cm.ali not less.
        I made less probes, changing damper resistor is still the same.
        I would ask for the proposal, what should be done to detect finer gold from 0.5-1 gram.
        Baracuda is not designed for finding fine gold. It is a beach detector intended to search for coins,
        For fine gold, you need to build the Minipulse Plus, which has a 2-stage pre-amp.
        • Thanks Qiaozhi
          I've already figured it out.
          Do this with the switch SW1 is still not clear to me, I read the forums and someone says this is a motion detector, others say it is a non-motion, a reading scheme and an explanation for barracuda rev.2 I found that the switch SW1 includes excludes mot. and non-mot.
          For me Barakuda only works if it is removed or if SW1 is turned off and when I turn it on from the speaker to hear a constant tone.
          I think that an electronic part to deny or can not detect it.
          On my Barracuda is winding probe of 28cm. copper wire 0.55 mm. 18 laps.
          1 euro detected at 30 cm. tweezers over 45cm. board sheet 60x60cm. 1.5 meters, air tests in the room, motion mode.
          I am pleased with this result but I wanted to try as non-motion
          • Can someone help me? I need a sprint layout from a baracuda pi with partslist.
            I have the one from the full construction details Thread , but the partslist contains only one 2M2 Resistor, i can see two at the board.
            I also have a partslist with 9 x 100n capacitors, the one from the full construction details thread has only 5. Is this a different layout?
            Can someone give me a working layout with partslist, easy to build , maybe easy to etch with a copper clad board, toner transfer.
            I need the board for a pinpointer.
            Thanks.
            • Use this
              http://www.geotech1.com/forums/showt...arauda-upgrade
              • Thanks, i cant find a partlist/BOM
                Is it the same as the regular Baracuda circuit?
                • Originally posted by BKY1337 View Post
                  Same partlist, except addition 10uf x2, some resistor change and an optional LT1054 for 7660.
                  Actualy look at the layout to make sure
                  • I dont have this partslist, Mine is very different with 3x 220 uF
                    I also need substitutes for 2N5485,MPS 102, and maybe 7660.
                    The LF 412 ACN is very expensive, about 4 Euro in Germany.
                    • This sucks, R25-R27 is missing and some Resistors are without Numbers.
                      • Comment
                          You should forget about the old Baracuda design. It contains numerous design errors, which are described in the Geotech Baracuda - REV-A Build Document.
                          If you need the REV-A version in Sprint Layout, then you'll have to duplicate the schematic and layout your own PCB.
                          • LOL or just jump that and go with the Mini that is even better.
                            • Which mini? I cant layout for myself. And i dont want to. I have thought that there are several workin versions of the baracuda with layout and partslist.
                              Whats the problem with the cuda cuda? Looks good , is single side, and small too, maybe a bit harder to etch.
                              I have the two versions from alex and ap, rev 2 , but i dont have a partslist which belongs to this, i cant find a 10 uF elko at the pcb , then i think i have the wrong one.
                              I want to order the parts today, but i need a bom.
                              Do you guys think that there is a problem with 5% Resistors instead of 1%?
                              • MiniPartsPlus. Nothing wrong with the Geo Barracuda. It does what it was made to do. Coins and stuff. I'm a Prospector and like the added elements of the Mini. What This Parts List? The Alix version? BarracudabuildParts.txt
