Serbian "Most Wanted"
  • Originally posted by The-Force View Post
    hello can anyone tell me what is the real size of this PCB in cm or mm.
    Thanks...
    78/94 mm
    • I worked three tiles of the same pattern, and no one does not work, why?
      I have osciloslop so I measured the multimer and everything is fine as the detector that works but my three tiles will not, where is the problem?
      When the device is connected to a battery of 12V from the speaker can be heard only a short ton, and nothing more, when you re-try the same and if the battery is constantly on and pushing a finger touch pad on the place marked green circle then heard from the speakers uniform tone. All integrated circuits, transistors, diodes I changed five times, measured resistance and nothing, all as before.
      To note also that the probe is working on the second detector normal. I'd like your help.
      http://oi58.tinypic.com/29dkdc8.jpg
      • Originally posted by walkman View Post
        These are my drawings SMW3
        Hi walkman ..send layout file please because that pictures very bad.. thank for send..
        • http://m.youtube.com/watch?v=tTaKZ_RnZHI
          • http://m.youtube.com/#/watch?v=6k0-ElV979I
            • hello mst, which Version of the layout files and coil you have used for the detector in Video?
              i have finished my Admiral v1 to a ready working detector just have to fill the coil with epoxi
              • is this SMW v2 or v3 ?
                • https://www.youtube.com/watch?v=tW6H...ature=youtu.be
                  made some tests yesterday
                  • Hi, I want to make version 3.0 of smw. Does anybody has made it and is everything ok with it. Can anyone from more experience members here explain how to set all these trimer pots here. Thanks
                    • ask for help
                      SMW working or unstable ! When budge probe runway , discrimination moose ! condensers to put that on the Tx and Rx , currently 470N and 68N
                      • What is process about coil wires? Does both end's of tx and rx going together with shield?
                        • both ends on shield does not work with mine (bad disc and gb behaviour)
                          bare unshielded coil work or only tx side shielded with graphit paint but i have also seen some People with massive foil shield
                            I don't have right now graphite, so my option is only alu foil.
                            Bernte, are u sure about TX shielded only? I heard about shielding only one side, but in my mind that was ever RX, or i'm wrong.
                            • Shield can make or break a coil when used in the field. I have never had any success using the aluminium covered Mylar blankets. In fact they have worked worse than having no shield.
                              Never tried aluminium kitchen foil.
                              Have more success using a flat card covered in a PVA glue graphite mix. Also not having much success connecting to the TX or RX in the coil found it better to keep the shield separate into the box an connect here (IDX and Bandido) although connecting in the coil will work fine on the bench.
                              The phase does alter when the shield is added. I use to aim for best null but now I use a range of small targets and go for best depth and ferrite still balances out.
                              • yes you are right i mean the receiver coil (RX) so shield the rx side
